SPIKER
Elite Member
Could be the chinese mfr is not playing by international "battery manufacturing rules" which ensure future battery sales. I had an OEM battery in a Nissan that lasted 11 years, and I didn't want to replace it because I was quite curious how much longer it might last. From that I've concluded that lead-acid batteries can last 11 or 12 years but are engineered to fail sooner. Possibly the OEMs have enough purchasing power to specify batteries that don't have that BS.
I was told by a chemistry professor that lead-acid batteries fail mainly because it's an engineered, timed chemical reaction that the industry spent considerable $$ to refine. They need the battery to fail shortly after, but never before a guaranteed life expectancy. Or at lease a life expectancy that is generally accepted by consumers.
Here's how it works. The lead plates have a certain amount of physical space above the bottom of the battery. When the lead (flaking off the plates) piles up and shorts out the plates, then one cell is dead, and the battery has failed. If the battery had more space above the bottom, it would last until the plates failed, which is not as predictable.
More months = more space for lead flakes. Sometimes batteries "revive" and I suspect this is because you take it out of the vehicle, handle it a little roughly, and cause whatever was shorting out that cell to dislodge. For example bumping it around on the concrete floor and re-settleing the pile of flakes that shorted that cell. Then you recharge it with some fancy charger and you think the charger healed it. Wrong, physical action 'failed' the engineered obsolescence (temporarily). Just my opinion.
You cant dump a old battery upside-down because the acid would dump out, and the flakes wouldn't come out. And they would short out more cells. If you could get under the plates and vacuum off the lead flakes then you could get more life out of your battery. If there was a battery life extender that worked, then I bet that company was bought out by a battery industry group (and scuttled).
I find that interesting, perhaps I will pull it out, (I have an old battery setting to trade for the new replacement.) Might have to pull that battery, use a vac suction to suck acid off from bottom into big glass gallon jar, see if crud is the cause.
the chemical stabilizer I sued claimed to reduce the sulphate-ion of the plates reducing the lead corrosion & flaking. Perhaps it worked, I looked into the top of the battery acid levels are all pretty good and plates appear very clean for it's age. figuring this thing has lived it's live bolted in place for 570+ hours over 12 years now in Ohio winters , this last one was pretty bad with a good bit of -20's...
Mark
