well pressure question
   / well pressure question #11
Othes have given references to sites for very good information/directions. Just a comment on house pressure.
There are 3 sstandard settings
20-40
30-50
40-60
20-40 is rare for good reason - really too low for good operation of sprinklers, showers, etc.
30-50 A good setting BUT. At the low end while it is adequate for a nice shower it is nothing to brag about.
Mine is set 30-50 and I do have a problem with some sprinklers.
40-60 - In my mind it is the best. Strong pressure throughout the range.
Settings over 60 (cut-out) are not recommended for residential use. It causes excess wear on fixtures.
Harry K
   / well pressure question #12
On the advice of a plumber whose experience was primarily city housing construction, I used 3/4" copper from my well to the house. My pressure switch is set for 20/40# and I find the flow barely adequate, tho the shower is ok. On my previous house, I used 1 1/4" copper from the pump and tank and had no volume or pressure problems with a 20/40# pressure switch. For those building new, I recommend using at least 1" pipe from the pump and pressure tank. It is hard to retrofit, so I will probably have to change my pressure switch.
Thanks everyone for taking the time to reply and for the info. im headed to the basement to see what i can see.
paul
   / well pressure question #14
</font><font color="blue" class="small">( On the advice of a plumber whose experience was primarily city housing construction, I used 3/4" copper from my well to the house. My pressure switch is set for 20/40# and I find the flow barely adequate, tho the shower is ok. On my previous house, I used 1 1/4" copper from the pump and tank and had no volume or pressure problems with a 20/40# pressure switch. For those building new, I recommend using at least 1" pipe from the pump and pressure tank. It is hard to retrofit, so I will probably have to change my pressure switch. )</font>
You shouldn't have to change the pressure switch - they are adjustable. 20-40 is definitely IMO way too low for adequate service. Jack it up to 30-50 at least and readjust the pre-charge.
Harry K
2018 CATERPILLAR 320 LONG REACH EXCAVATOR (A51246)
2018 CATERPILLAR...
UNUSED HURRICANE STAND ON SKID STEER (A51247)
UNUSED HURRICANE...
2010 Chevrolet HHR SUV (A51694)
2010 Chevrolet HHR...
(INOP) YALE GLC040RGNUAQ084 WAREHOUSE FORKLIFT (A51247)
(INOP) YALE...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51247)
(INOP) JOHN DEERE...
CABINET OF HOSE ENDS (A53843)
CABINET OF HOSE...
