Well presure adjustmet
   / Well presure adjustmet
Thingy,
I turned the large nut/shaft gradualy 3 times and I got 2 lbs. So far not noticable but she going up!
   / Well presure adjustmet #12
Good,just keep playing around,,,I got mine to cooperate,,I got one of those low cut off pressure switches,,,pressure get down so low,you got to ,turn switch by hand,,designed to cut off before water runs out,,,good idea,,,,but my cut on was below or equal to that,,,so I turned the nuts up,,been working good for about a year now,,sounds like you ain't got no problem at all,,,thingy
   / Well presure adjustmet #13
scott_vt said:
Evenin Paddy,
In any event sounds like your on the right track. BTW I keep a spare down in the cellar just incase ;) :)
Yes. Especially since Murphy's law is always in effect. When the switch fails (and it will), it will be at 6 pm on a Saturday night in the middle of snow storm.
Harry K
   / Well presure adjustmet #14
Well I can't dispute that failure turnkey4099, but I can assure you the capacitor will fail in the pump control box on a Sunday at 6 pm. We don't see much snow but it was raining.
   / Well presure adjustmet #15
scott_vt said:
Evenin Paddy,
All good suggestions on the thread, but Im thinkin that if you have a 20/40 switch your not gonna be able to adjust it to 30/50 . You can only get so much variation out of the lower pressure switch.
All (Sq D) switchs are adjustable as I described; they just come preadjusted to 20/40, 30/50 or 40/60 psi. So do Furnas switchs and they adjust with a tall spring screw (adjusts range [30/50] together) and a bolt head (adjusts cut-off only).
Gary
Quality Water Associates
Gary,
I got agressive and was able to get 40/60. The blader tank needed a big boost but all is much better. Thanks again all
   / Well presure adjustmet #17
Well alright,,,nice when a plan comes together,,,thingy
2001 CHEVEROLET C6500 3 CAR ROLL BACK (A54607)
2001 CHEVEROLET...
10ft Enclosed Cargo Trailer (A55758)
10ft Enclosed...
2006 TEREX FRONT DISCHARGE CONCRETE TRUCK (A54313)
2006 TEREX FRONT...
2018 Ford Fusion Hybird (A55758)
2018 Ford Fusion...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
2018 Ford Explorer AWD SUV (A53424)
2018 Ford Explorer...
