turnkey4099
Elite Member
</font><font color="blue" class="small">( All submersible pumps are not equal. Remember this is 5 HP. at 400 ft. with a high flow rate.[ when considering conventional use] Depth means more stages for pressure and volume will require larger diameter impellers. The materials for this type of pump may also be slightly different from the conventional home owners submersible.
Egon )</font>
A bit pedantic:
On the questionof depth: It isn't the depth the pump is at that counts, it is the head. for example, a pump at 400 ft but he level of water during drawdown is at 100 ft, the pump is only pumping against 100 ft of head, not 400.
High volume under any circumstances does call for bigger pumps just as you said.
Harry K
Egon )</font>
A bit pedantic:
Harry K
