DarkBlack
Elite Member
Your well setup falls in the middle of a Goulds 1hp pump as far as selecting head vs gpm.
Goulds 5hp motor alone is 70 lbs.
Putting on a "real" 5hp motor is just plain bad. Now you have a huge starting torque on a 1-1/2 hp pump mass. This means your torque tube is going to shift every time that huge motor starts, as it doesn't have an accompanying mass of pump bolted on, to resist rotation. Did they put on multiple torque tubes at least? If not, you'll be replacing broken wires or a split pipe after a couple years. Besides the extra $1k for the motor you had to change to oversized copper cables to prevent a voltage drop. Those aren't cheap. And lastly, If you're like me and want your mid sized portable generator to run your pump, forget it with your pump motor.
I see only drawbacks to a grossly oversized motor.
