Well tank has pin hole leak, is there a good stainless steel option?
   / Well tank has pin hole leak, is there a good stainless steel option? #1
Wnc3
S.E., Texas
John Deere 820 utility, John Deere 5525, 997 JD Zmower, Komatsu PC 35 miniExcavator
My galvanized tank rusted out and I would like to try stainless. Does anyone have a good source?
If I can't get stainless, I will go with fiberglass. I don't want a bladder, just the tank.
My tank lasted only 10 years and we have good water...
Thx
   / Well tank has pin hole leak, is there a good stainless steel option? #3
Don't discount bladder tanks. I know Well-X-Trol puts the water in the bladder, so that there is no contact to the steel tank. I have one in service for 25 years, no problems. The trick is to get the larger diameter tank, and a larger size. With that combo there is much less flex on the bladder, and longer life.
paul
   / Well tank has pin hole leak, is there a good stainless steel option? #4
Thx
Just curious. Why not a bladder - lots less maintenance and the wate doesn't touch the tank. Failures of the bladder are rare.
Harry K
I had one with a bladder and it only lasted 5 yrs. The two well guys I talked to also said that they have more issues with bladder tanks. It just seems like stainless would last 30 plus years.
   / Well tank has pin hole leak, is there a good stainless steel option? #6
My bladder tanks now are 20-25 years old, I don't know how old you are, but you might want to pass the replacement on to the next owner. SS tanks are not cheap.
   / Well tank has pin hole leak, is there a good stainless steel option? #7
They now make composite bladderless well tanks. Look into the Flexcon or the Well Mate brand, they each have one.
If you still want metal, perhaps you should investigate the 150 psi Quicktank. Regular galv. quicktanks are only rated for 75 psi, I assume that 150 psi would be slightly thicker.
I would assume stainless would cost several thousand, a regular 82 gallon galv. tank is about $500 +/-
   / Well tank has pin hole leak, is there a good stainless steel option? #8
paul
I have to agree with Paul on the Well-X-trol mine is a least 20-25 yrs old but, it started making a some noise about a month ago so I may have to replace it soon and I will go back with the same. Well-X-Trol is American made.
   / Well tank has pin hole leak, is there a good stainless steel option? #9
I also have the same brand. IIANM the bladder is replaceable in them. From what I have heard, replacing them is a nightmare.
Harry K
Thanks for your responses. Stainless is out due to cost. I will post what I install...
2014 International ProStar Truck, VIN # 3HSDHSJR1EN768255 (A51572)
2014 International...
2020 COLOMBO TM LOT NUMBER 218 (A53084)
2020 COLOMBO TM...
2012 Hyundai Genesis Sedan (A51694)
2012 Hyundai...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
CATERPILLAR V50B STRAIGHT MAST FORKLIFT (A51246)
CATERPILLAR V50B...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
