Well that was stupid
   / Well that was stupid #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
OK, just so others can feel good about themselves. Welding a large sculpture. 1/8" x 4" square tubing. Got some scrap to test with and get my settings right. Played and played and finally felt I had dialed in my welder (the settings on the panel seems too agressive). Was ready to weld. Friend stopped by, said hey, can you weld this X together real quick. And I did. He was happy, I was happy he was happy. He drove away. I grabbed up my welder and grabbed my sculpture and burned a hole right through it. Never reset my welder and to make it worse in all of my fluster I completely forgot what settings I had settled on.
   / Well that was stupid #2
You don't know whether to laugh or cry when those things happen.
   / Well that was stupid #3
Happens to the best if us... And Im far from the best so i do it more than most!
A little time on a low heat setting and some grinder work and you'll patch that right up!
   / Well that was stupid #4
I can commiserate with you! :laughing: Working on something small and intricate, then think to myself, hey, I got the welder out. Might be a good time to repair that big thing I've been putting off. Feel all good about getting the big thing done, then go back to the intricate work and blow a hole through it. :confused3:
   / Well that was stupid #6
I am pretty sure most of us have done what you did least once.....twice. :eek:
   / Well that was stupid #7
You can fix that. Dumb is something you can't fix. Stop by; I've got lots of examples.
Once I welded a nice piece of work to the plate welding table top. Duh, and I know better.
   / Well that was stupid #8
As a consolation prize, you should know you are the last man on this earth that will every make a welding mistake. :D
Thank you for taking one for the team. :thumbsup:
Heck I make several welding mistakes on every project I work on.
On this last project I made (my grapple bush grabber project), I took my time and carefully measured and drilled four 1/2 inch holes thru the thick steel upper plate and just a bit later when I tried to fit in on the grapple I notice that one hole was about 3/8 of an inch out of place.
Well poop!. I drilled another and welded up the original.
Hey the ability to weld holes shut is just a bonus with owning a welder.:)
John Deere 5065E 2WD Tractor with Canopy (A55314)
John Deere 5065E...
2006 JLG 2030ES 20ft Electric Scissor Lift (A54811)
2006 JLG 2030ES...
2020 MACK PINNACLE DAY CAB (A53426)
2020 MACK PINNACLE...
2020 Deere 50G (A53317)
2020 Deere 50G...
STORAGE SHELTER KIT (A53843)
STORAGE SHELTER...
2008 Chevrolet Impala LT Sedan (A55853)
2008 Chevrolet...
