Well Water Quality - Tests - Readings
   / Well Water Quality - Tests - Readings #11
mikim,
The back wash is high in sodium (or salt) and if you have a concrete septic tank it will eventually eat through it, destroy it, whatever. The sodium will also kill bacteria to some extent. Bacteria is good for the septic system. My back wash goes into the sump to be pumped elsewhere.
I think Jerry answered the Septic Field Questions for me. Thanks Jerry. Jim, got it on the dead ends - Septic is a tank with leech field - I didn't ask WHY it wasn't good, just took their word on it. Understand it's just during the backflush phase - Couldn't imagine a softner would force a salt water shower!
JJT, twasn't I that suggested plugging up a field - It was mikim. Ask him! But I think Jerry answered all our questions.
   / Well Water Quality - Tests - Readings #14
I design industrial water purification systems for a living. Softening removes dissolved calcium, magnesium, and low levels of iron from water, but in turn increases dissolved sodium levels, which comes from the salt used for regeneration. Too much sodium can be bad for you, but your water is not very hard, so the amount of sodium will be small in relation to that present in food.
Eventually you may have to chemically clean the softener resin if it becomes iron fouled.
There are filters which use natural or synthetic geensands and remove most forms of iron and manganese (even at much higher levels) without softening. They typically use potassium permanganate (or sometimes bleach) for regeneration. I prefer the type of iron filter which regenerates intermittently instead of continuously, as it is less likely to put residual chemical in your water. Mechanically, they are very similar to a softener and cost about the same.
Softener resin has a softening capacity of about 30,000 grains of hardness per cubic foot. At 4 grains per gallon hardness level, you will be able to soften 7,500 gallons of water (per cu. ft. of resin) between regenerations. It takes about 15 pounds of salt to regenerate one cubic foot of softener resin.
Whichever way you go, triggering regeneration with a water meter (vs. a timeclock) is more expensive to buy up front, but more efficient in the long run, as it saves both chemical and regeneration water.
2013 Ford F-550 Passenger Bus (A51692)
2013 Ford F-550...
Ingersoll-Rand Winch (A53117)
Ingersoll-Rand...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
Toro MBTX 2500 Mud Buggy (A53117)
Toro MBTX 2500 Mud...
Light Tower (A52377)
2017 HYDREMA 912HM ARTICULATED DUMP TRUCK (A52706)
2017 HYDREMA 912HM...
