Wet brakes vs. dry brakes
   / Wet brakes vs. dry brakes #1
LabLuvR
SC
Kubota MX5400
Can someone explain the difference and if one type is significantly better than the other? Thanks!
   / Wet brakes vs. dry brakes #2
Wet brakes run in oil,keeps them cool under heavy use,as turning with brake at end of field. wet brakes will last longer,require less adjustments and so on. They are internaly mounted meaning if you have to replace your have to drain trans.oil. most wet brakes are a multibile disc set up making more stoping power. Dry are mostly single disc or drum will heat under heavy use and wear more quickly,but are a slight bit faster to replace,not as much stoping power. the wet brakes are the better set up. but on a tractor you should not replace brakes for a very long time any how. most tractors gear or hydro will al most stop themselfs if you let of throtle or hydro peddle.
Ryobi Sliding Miter Saw (A44391)
Ryobi Sliding...
2011 Nissan Pathfinder 4WD SUV (A44572)
2011 Nissan...
1998 Dodge Ram 3500 Extended Cab Pickup Truck (A44572)
1998 Dodge Ram...
1999 Ford Econoline Van, VIN # 1FTRE14W0XHB81450 (A44391)
1999 Ford...
2002 Ford F-150 Pickup Truck, VIN # 1FTRW07332KD61848 (A44391)
2002 Ford F-150...
2016 KENWORTH T680 TANDEM AXLE SLEEPER (A43004)
2016 KENWORTH T680...
