Wet brakes vs. dry brakes
   / Wet brakes vs. dry brakes #1
LabLuvR
SC
Kubota MX5400
Can someone explain the difference and if one type is significantly better than the other? Thanks!
   / Wet brakes vs. dry brakes #2
Wet brakes run in oil,keeps them cool under heavy use,as turning with brake at end of field. wet brakes will last longer,require less adjustments and so on. They are internaly mounted meaning if you have to replace your have to drain trans.oil. most wet brakes are a multibile disc set up making more stoping power. Dry are mostly single disc or drum will heat under heavy use and wear more quickly,but are a slight bit faster to replace,not as much stoping power. the wet brakes are the better set up. but on a tractor you should not replace brakes for a very long time any how. most tractors gear or hydro will al most stop themselfs if you let of throtle or hydro peddle.
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A53473)
2012 KINZE FLAT...
2003 Ford F-250 Knapheide Service Truck (A51692)
2003 Ford F-250...
2016 Freightliner TMA (A52377)
2016 Freightliner...
2004 Ford F-250 4x4 Service Truck with Liftgate (A53422)
2004 Ford F-250...
2007 JOHN DEERE 7630 TRACTOR (A53843)
2007 JOHN DEERE...
2005 PETERBILT 379 (A53843)
2005 PETERBILT 379...
