wet clutch
   / wet clutch #1
BHM
tandragee
MF
Can a wet clutch work the same as a dry clutch pressured with springs, does there need to be more springs on the wet clutch, if it is the same could a dry 13" clutch on a tractor be converted to a wet one.
   / wet clutch #2
Hi. Welcome. Don't think wet and dry clutches are the same animal. Usually wet clutches are multi-disc.
   / wet clutch
Hi, If a wet single brake disc works to stop with, could a single clutch disc work to start with.
   / wet clutch #4
The difference between the brake and clutch is the brake is stopping the momentum of the tractor. The clutch is applying force to drive the tractor beyond just its weight. A lot more force is on the clutch compared to the break. Converting a dry clutch to wet will not provide enough friction when wet to drive the tractor. This is the reason wet clutches are multi-disc to increase the surface area of contact.
   / wet clutch
Do you think there would be enough friction if a duel clutch could be converted, the two clutch plates to drive with, that it some one could make discs for me as it could not be got of the shelf.
   / wet clutch #6
Not sure what you are trying to accomplish. Dry clutches fail if they get wet or oil on them. They were not designed for wet applications.
   / wet clutch #7
Thread moved to Owning/Operating.
2025 AGT ATK-B1000 (A50123)
2025 AGT ATK-B1000...
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
2017 UTILITY 102" X 53' VAN TRAILER (A51247)
2017 UTILITY 102"...
UNUSED HURRICANE 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
WHIRLPOOL GOLD REFRIGERATOR/FREEZER (A51248)
WHIRLPOOL GOLD...
100' Roll of new 5/8"/16mm Crane Cable  (A52384)
100' Roll of new...
