What about BKT brand tires ?
   / What about BKT brand tires ? #1
DrBill
Murfreesboro,Tn.
755 and GT245, also IH Cubs, 1450 and 1650
Has anyone used any BKT brand tires on their tractor ??
Thanks
   / What about BKT brand tires ? #2
I think I have the BKT on a 1650 oliver. Came from India I believe and were as cheap as I could find locally. Tractor just used for hay so I can not offer much insight. Did mount them at home.
   / What about BKT brand tires ? #3
Yes. Put a set on my Massey. I researched it well and they seem to have the best reputation other than Firestone or michelins. And they are reasonably priced. Been very happy with mine
   / What about BKT brand tires ? #4
Thanks
I use them on my garden tractor, 6ply trencher tires. I can run them with very low pressure for better grip in the snow with my blower so I don't have to use chains on the driveway. I get good ride when cutting grass also over roots. max load is something like 1700 lbs per tire. I'm very happy with them and they are priced good. I think I paid $135 for two 23x10.5x12 6 ply trencher delivered to my door. I got them from GCT wholesale. Took three days to ship.
   / What about BKT brand tires ? #5
Have them on several tractors, good tires decent price. Slightly softer rubber than some other brands, you may find that they wear a little faster if you drive a lot on asphalt. Otherwise good durability
   / What about BKT brand tires ? #6
You will be happy with BKT tires. What size do you need?
Thank you everybody ! I appreciate everyone's answers about these tires... I have a deere 755 that I basically remanufactured and have running well enough to finish off my life with.. (Mainly mowing on level ground during summer months). I'm running "MayPop" tires however,, and if I replace them with the brand names that came on it, it appears I'd spend almost as much as I paid for the thing to begin with !
Millertire,, I see your info,,, I've got 23x8.50-12 up front, and 31x12.50-15 in the rear.. In my case, I would be hoping for a turf type tread.. Lower ply where possible..
   / What about BKT brand tires ? #8
I bought 1 BKT tire at my farmers coop about two years ago. I mounted it without a tube. The tire has held up well on my bushhog tractor.
   / What about BKT brand tires ? #10
I should have said looking for 8.3 x 22
2016 KUBOTA K008-3 MINI EXCAVATOR (A52709)
2016 KUBOTA K008-3...
. T/A TRASH TRAILER (A58216)
. T/A TRASH...
Set of 4 10-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 10-16.5...
10,000 PSI AIR HYDRAULIC PUMP (A58216)
10,000 PSI AIR...
LOT: Clevis Hook, Snatch Block (A59076)
LOT: Clevis Hook...
Sakai SV540T Padfoot Compact Roller (A57453)
Sakai SV540T...
