wHAT ABOUT DIXON O TURNS
   / wHAT ABOUT DIXON O TURNS #11
Thanks, Walt! Seems your generosity is exceeded only by your credentials. :)
For any that wonder about this tidbit the cone drive is a friction-contact V-S drive system, with friction mat'l 'cones' moving in CI 'cups'. What I mean about 'hard' is horsing (rushing thru') typical wye 180-turns at the end of a pass, so the cones are glossy vs the 'rougher' look of a similar brake lining on caliper pad or shoe and it always feels like something's slipping. No way it'd push the factory snow plow this way even with chains & wheel wts vs 'as new'.
With a hydro, such use only seems to heat up the oil, and I've seen but one drive motor give out from 'hard' use on a mid-'90s Country Clipper 60" (25hp 'Klr') from trying to drive out of a wet ditch, so more weight can help or hurt. That said, we speak of power and cut but rarely discuss o'all weight when shopping for ZTs. Power-tilt decks, ROPS, 'pro' features and such can add quite a bit to that.
btw, Digressing then just a bit from Dixon/Husky, a friend lamented buying a 54" Gravely (Kaw power) vs a 60" something for his ~2 1/2 ac to mow. What I noticed right away was how light it looks and specs, that the deck isn't so much wider than o'all stance. What he admitted was that he's in and out of his ditches with a better cut and less rutting than the guy next door's fancier (heavier) 60". (I complimented the 'lemonade' he's been making. ;)) This goes back to being sure that a selection considers every detail of routine cutting.
Eddy g, if you are particular about engine (brand) choice I urge you not to compromise. Some of us won't have Kohler, thinking that dropping in a new B&S is perhaps as affordable, but much faster, than rebuilding the Kohler. (Diff'rent strokes, right or wrong) No exp here yet with Kaw, but the comments I hear from 'pros' gassing their fleets at the pumps has always been positive. If we don't help you choose which brand to buy we'll sure be here to help you keep 'er going, esp if you do your own maint/service.
Walt, thanks again. I'll be in touch if I ever catch my tail. :laughing:
   / wHAT ABOUT DIXON O TURNS #12
"Some of us won't have Kohler,"
Kohler Courage - NO, Kohler Command will wear out 2 -3 B&S and I am B&S man mainly because of simplicity, interchangeability, ease of getting parts and price.
"What I mean about 'hard' is horsing (rushing thru') typical wye 180-turns at the end of a pass, so the cones are glossy vs the 'rougher' look of a similar brake lining on caliper pad or shoe and it always feels like something's slipping. No way it'd push the factory snow plow this way even with chains & wheel wts vs 'as new'."
I think you problem is something other than "glazed cones".
Walt Conner
   / wHAT ABOUT DIXON O TURNS #13
"No way it'd push the factory snow plow this way even with chains & wheel wts vs 'as new"
Should have included that I used to put the front wheels against the front steps and slip the rear tire one side at a time on the dry concrete to check adjustment. I said used to because wife doesn't like black marks on the new concrete driveway. So again I say, I think your problem is something other than glazed cones.
Walt Conner
   / wHAT ABOUT DIXON O TURNS #14
Expect the CI 'cups' to be smooth as if polished, but when replaced cones were new (and on the 36") some water would stick to them at cleanup time. (I clean, they don't) On the 42" cones look/feel like they were given two coats of clear lacquer, very hard now-pitless & glossy surface that water beads up on and rolls off of differently.
Reminds of new brake shoes/pads not seated well or driven carefully for a few to seat/break in and not getting grip on drum/disk. Feel when operating is somewhat like driving the smaller one with a wrong belt that wouldn't tighten, and already-slow stick response lagging worse. (Just that much more different response than w/hydro drives.)
I doubt (so far) that any lube or other contaminant is a factor. Reliable dealer/serviceman asked if I mowed in a hurry and agreed with likely cause, advised 'scuffing' them like a reinstalled shoe, pad, or clutch lining (not much access, .. and while running :eek:) Decades of mill, lathe, and grinder work here and still have all ten thumbs :laughing: so not skeered to go there if need be.
Walt, lets go to PM/email and hope the thread steers back to current models for those interested. I'm sure you have much to offer, and will look for ways to return any .. 'favors'. jon
   / wHAT ABOUT DIXON O TURNS #15
My wife bought a Dixon SpeedZTR42 about 4 or 5 years ago, before we were married. I'd never heard of them before, but the Husqy dealer she bought her Husqy rider from sold her on one. Yeah, they're not the best quality on the planet, but they do work. She's broken those cast aluminum connectors on a few occasions catching the handles on peach tree limbs. Dealer told here they were designed to break in just such a scenario. She keeps a couple spares on hand now. Over time, though, we've come to find that they're really not well-suited to heavier use. We mow about 2-1/2 acres every week (around lots of trees), and it does OK with everything except the denser or wetter stuff. It also doesn't care for taller stuff, and clogs easily. We have to use the Husqy for that.
A couple of weeks ago, the blades shut off while I was mowing. After it cooled, they worked again for awhile, but kept shutting off again. Checked connections, and they seem fine. So, I'm guessing either the switch or a solenoid is heating up and failing. Haven't dug that far into it yet. We've talked about trading up, so I may not bother.
I think they would be fine for the average homeowner who doesn't mow a lot of property and doesn't let anything get too tall. With our experience, though, I wouldn't consider them really "farm-worthy."
   / wHAT ABOUT DIXON O TURNS #16
You are unfortunate enough to have a Husqvarna/Dixon with Husqvarna quality. Two blade deck I expect.
Walt Conner
   / wHAT ABOUT DIXON O TURNS #17
Surprisingly, it's a 3-blade.
(edit - check that ... it's a 2-blade, the Husqy is a 3-blade)
We've never had any issues with our Husqy stuff. We're on the second tractor only because she wanted to upgrade about two years ago. Husqy trimmer still fires right up every time, too.
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2016 FREIGHTLINER...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
1266 (A50490)
1266 (A50490)
2015 TOP HAT TRAILER 20 FOOT UTILITY TRAILER (A53843)
2015 TOP HAT...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
