What an I doing wrong with my FEL?
   / What an I doing wrong with my FEL? #22
Toothbar required. Too much resistance from the loader blade. There is no way to get around the need for one. It's the cheapest, most productive item you can add to your machine.
   / What an I doing wrong with my FEL? #23
</font><font color="blue" class="small">( With a pile like that that angle in with only part of the bucket in use and break out the dirt. You can also go to the opposite side and push ftrom the top to loosen things up. Then back up and go for the full load.
Egon )</font>
The BH works good to break up the dirt .
So does the tiller .
Some times I use the BH and then the tiller depending on what I'm going to use the dirt for & how fine I want it.
   / What an I doing wrong with my FEL? #24
</font><font color="blue" class="small">( Have a L3130 HST with LA 723 FEL. I like it, but when driving into a large pile of dirt, as noted in the attached picture, the engine will die out unless I put in the clutch. I then let out the clutch and can curl it and start to lift and it's ok. Newbie at this Live Hydraulics Loader thing, so probably doing something wrong.
penokee /forums/images/graemlins/smile.gif )</font>
http://www.tractorbynet.com/forums/download.php?Number=681690
The trick in a pile of dirt like this is to know when to curl and lift the bucket.
It takes a little pratice but it comes to you.
Don't wait to lift the load after your jamed tignt into the pile.
If this happens to me i simply back the tractor up while raising the fel,It's easy and quick to do this with my BX23 thanks to the HST.
Work from near the top of the pile down not from the ground up.
Here are a couple more tricks I use depending on the situation and what i plan on doing with the dirt.
1/ Use the BH to break up the dirt
2/ I have a 1967 Bolens with a tiller on the back that i just back the tiller into the dirt pile and till it up.
Sometimes i use 1 followed by 2.
Hope this helps you out a bit.
SINGER 211 UPHOLSTERY SEWING MACHINE (A54757)
SINGER 211...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
Giyi Excavator Root Rake (A53316)
Giyi Excavator...
2007 Hyundai Sonata GLS Sedan (A54815)
2007 Hyundai...
2019 Ford Fusion Sedan (A55758)
2019 Ford Fusion...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
