what are the fixtures on my loader for?
   / what are the fixtures on my loader for? #1
M_Brown
Bronze Member
Poulsbo,Wa USA
Kubota B7100
My B7100 loader has these fixtures on both ends of the FEL bucket. One is a pin that sticks straight up, one is a square lug with threads in it and a hole in the end of the bucket that lines up with it, like a bolt could go though the hole and thread into the lug. The last one is a loop welded to the end of the bucket. Both ends of the bucket are the same.
   / what are the fixtures on my loader for? #2
Chances are very good all will be used when removing the loader from the tractor.:D
   / what are the fixtures on my loader for? #3
Yep, used for support legs when removing loader. There should be some "L" shaped bolts on the front of the tractor holding the loader in a cradle and the are supports legs attached with pins from side to side behind the steering wheel, also a second set of legs located on spring clips, left of tractor , on the inside rail of loader frame...maybe you're missing some pcs.?
   / what are the fixtures on my loader for? #4
My 1995 B7100 with the B1630C loader had the same thing and I never did find out what they were for. The front end loader was not a quick attach and, of course, was never removed from the tractor.
Thanks for the reponses! I think I am missing all those parts. I bought tractor used but not from the original owner. I purchased all manuals except the loader. An yup,it is not an easy attach/detach loader like Bird says. I did not want to spend the money on the Loader manual. Does anyone perhaps have a picture of the parts or a drawing of the parts and how to use them? I don't have any plans on removing the loader right away, but ya never know. I am one of those people that wants to know everything I can about my equipment. Mike
   / what are the fixtures on my loader for? #6
Just one overall picture from my model LA300 loader. If more wanted I can copy from the manual.:D
Egon, Thanks for the drawing, now it all makes sense. I don't have any of those parts with my tractor but I'm sure I can come up with something that will work. Thanks again...Mike
