what are you using for road bed?
   / what are you using for road bed? #11
In CA, civil engineers and the county or city will specify so-called
Class 2 base rock, which is a mixture of gravel (3/4 minus, I believe),
sand, and a small amount of clay binder. It then has to be compacted,
usually to 95%, and then tested. Quarries and engineers usually
just call this stuff "base rock", and it is used under asphalt (A.C.) or
oil-and-screen pavements, or to embed culverts. It is not intended
as the wear surface. The cheapest pavement here is oil-and-screen,
which can work quite well on a good base with good drainage. This is
the kind of pavement they laid in Cool Hand Luke, if you saw that movie.
BTW, my road I paved with asphalt when it was $50/ton. It is about
$350/ton now, making Portland-based concrete less expensive for
materials now.
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A52377)
2017 Ford F-350...
2011 Chevrolet Equinox SUV (A53424)
2011 Chevrolet...
2013 CATERPILLAR D5K2XL CRAWLER DOZER (A52705)
2013 CATERPILLAR...
2023 Bobcat T66 (A50120)
2023 Bobcat T66...
1996 International Water Truck with a Caterpillar Engine (A55218)
1996 International...
2004 Workhorse W22 Motorhome (A53424)
2004 Workhorse W22...
