What are your general implement care routines?
   / What are your general implement care routines? #11
I blow everything off with compressed air before taking off and setting them on something that'll allow them to be moved. For the bush hog, I put the front onto a 2x6 that has STEEL castors underneath: 3 on each end. The chipper/shredder goes onto a little dolly built for it. A furniture dolly might work. Have castors underneath the carryall, again STEEL; I occasionally forget to raise it. Plastic won't survive. Don't bother with underneath the bush hog, because it's usually dry when I use it, and stuff doesn't stick there when dry.
On my old LX4, I eventually extracted the oil from it (when hot) and replaced it; haven't done this yet on the Frontier. Every spring, I put the rear end up on jack stands and remove the tail wheel and remove the blades. Grind the bad spots out as best I can and do a pseudo sharpening job and put the blades back on. Then run around with the tail wheel off for a while knocking down briers that I can see now with other stuff around, etc. and then retorque the nuts with my precision 6 foot pipe on a 3/4" drive and pushing as hard as I can to hopefully get 450-500 ft lb.
Regrease the chipper/shredder's 3 zerks generally before using it again. Occasionally grease the U joints on the bush hog and chipper/shredder but not too religious about it because too easy to over grease them.
Occasionally give the back blade rotating blade apparati a few shots of silicone lube.
Stuff is all stored inside on concrete.
Ralph
2012 Toyota Camry Sedan (A50324)
2012 Toyota Camry...
2024 Isuzu NRR 24ft Box Truck (A50323)
2024 Isuzu NRR...
JMR Attachments Tree Boom (A50121)
JMR Attachments...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
JLG 1255 Telehandler (A52748)
JLG 1255...
