GaryM
Veteran Member
To smooth the rock on my drive I put the bucket down but pretty flat so the curl cylinders are barely extended and use reverse. It's generally best, with a small tractor at least, to not put too much pressure on the curl cylinders. If they bend it's quite expensive I'm told. Driving forwards is not quite the issue as the cylinders are in tension.
