What brand filters and engine oil in your kubotas?
   / What brand filters and engine oil in your kubotas? #91
I quit using and selling Wix filters after tearing one apart.
Substandard trash.
Use OEM or find a quality replacement, Wix is not one of them!
Regards, Fred
   / What brand filters and engine oil in your kubotas? #92
Just taking a survey to see what filters and engine oil everyone is using in their kubotas?
Today I came across NAPA's filter sale flyer and was told NAPA filters would be 40 to 60% off (September 8 - 27). Also NAPA will have Valvoline Premium Blue HD Diesel Motor Oil 10w 30 and 15w 40 on sale for $11.99 per gal. I am contemplating switching.
I run my old BX2200 about 100 hrs. per year. With that I use OEM filters and SUDT2 trans fluid. Rotella T6 for the engine. Never have had an issue. 1357hrs on the BX. Cost difference in filters and trans fluid make OEM the better choice to make sure the right stuff is doing the job.
   / What brand filters and engine oil in your kubotas? #93
I'm with daves1708 all the way. If I had a BX25, I'd be installing a real fuel filter. Think about boat engines, and the fuel conditioning systems they run, since a clogged fuel system on the water can be serious.
Aircraft- more careful fuel management before it goes into the fuel tank, but I have seen idiots pump JP 4 (kerosene) into piston engine aircraft that required 100 octane av gas to run. Luckily, the takeoff was delayed, so the engine quit on the taxiway, not 100 feet over the end of the runway.
   / What brand filters and engine oil in your kubotas? #94
Top secret... the best freight price you will get is over the phone. Many of the parts don't have weights in Kubota's database so the website does a lot of guessing. If you just call in and tell the parts guys to charge you the actual UPS or Fedex rate when its on the scale you'll pay the actual rate and not calculated guess.
877-260-35285
Plus then you get to talk to a smart "parts" guy. I've called Messicks in the past and have been politely told I could get the exact same minor part not labeled Kubota for 1/3 the cost.
I discovered that Messicks usually quotes UPS shipping, because they figure most customers want whatever they order ASAP, but they can ship for less with USPS if you can wait. eBay is good for finding genuine Kubota filters. Wallyworld for Shell Rotella diesel oil.
Messicks does ship ASAP. I found I better make room on my shelf BEFORE I order because it will be there ASAP.
<snip>
If you aren't sure your oil choice is doing the job, get an oil analysis.
<snip>
Get a UAO occasionally anyways, peace of mind.
   / What brand filters and engine oil in your kubotas? #95
I got to confused, unsure and tied of online searching of where which what Wix oil filter to get, so I ordered Kubota oil and fuel filters and motor oil from Coleman Equipment. It's the easiest web site I found, type in my tractor and what I want and there it is, click on the shipping rate for what I want and the price is right there, the shipping cost is almost $11.00, not bad for what I got and half-way across the country.
I went to the Wix web site, and the oil filter I found that's supposed to fit is 51307, I wanted to be sure so I email Wix, quick response back, they sent me a different no. 51311, maybe they both fit, maybe nether fit, maybe I'll have a fit. I looked up fuel filter no. found 33830, looks like what I use, but no O rings with it, where's the blanking OOOO rings. Wix gave me a different fuel filter no. 33507, I looked that up and that didn't look right at all, and no O rings.
At the Coleman site when the fuel filter comes up, down lower on the page it says, you might want O rings, Yes yes I want O rings, not sure but when replacing the fuel filter on diesel engines, I think it has to seat right or could cause a lot of speaking in tongue's, changing the fuel filter still makes me nervous.
   / What brand filters and engine oil in your kubotas? #96
Oldpath05, sounds like you've found 'the place' and they've treated you right!
Cummins use Fleetguard filters because they own Fleetguard, and make their own branded filters. On their diesel pickup engines, there are at least three numbers that the factory lists as acceptable because they have evolved new filters in the intervening years. All three are good. All the designers require is so much pressure, at so much volume, and there is no such thing as THE best filter for an engine, manufacturers just list a single for convenience, and to keep each individual from having to pour over thousands of filters!
I don't have anything at all against any filter someone likes, and as I've said before, if the Kubota dealer were closer, I'd likely just go there, with the exception of the fuel filter, I will not use the Kubota filter for that.
But you found a great place, that treats you well, and THAT customer service is the success for BOTH of you!
George
   / What brand filters and engine oil in your kubotas? #97
It seems like this thread has become mostly concerned with the cost of oils and filters so I'd like to propose a different way of looking at cost.
I suspect my credentials are roughly average for a mechanical group. Started as a heavy machine operator and then a mechanic, machinist, shopowner, and much later (at 50+) a degree in mechanical engineering. Incredibly though it seems, that last gig has now lasted over twenty years.
Oils and filters have changed a lot during that time, but then so have the ways that I look at them.
Back to price, I simply don't see any significant difference between any of the oil and filters on the market as regards price or availability. It's a narrow range, and they all seem to be somewhere in roughly the same small ballpark. We know we have to have both, and that we have to change them periodically. So it's lucky for us that both are so inexpensive. What small differences in price they do have grows even less significant when compared to the cost of the systems these things are protecting.
Engineers often run across roughly equal claims for roughly equal products and part of the job is making a specsmanship call. The client decides just where he wants to end up on a sliding scale of price versus quality and the engineer has a varying degree of voice in that decision.
But when it's something left to me and especially on my own equipment I like to start with the most expensive example and ask just what it is that makes that product more expensive.....and whatever it is, does it have any value to me?
That way I'm basically counting on competition to keep the price as low as it can be; I may be wrong, but that seems to be a reasonable assumption when all the competition is making something that is roughly similar. It's possible that the more expensive part might really be better, whereas that argument is sure a lot harder to make for the less expensive examples. Manufacturing anything is a pretty small world. In the world of manufacturing, it is common to continuously monitor competing products. When the product and process are so similar it really does cost more to make something better.
Again, compared to engines and hydraulic systems, oils and filters are so cheap to start with that if one really is better then that's the one we want. So I start by looking at the high end, not the low price.
And not wanting to be a fool, it's worth thinking about some of the other things that can raise price; things such as advertising, size of the manufacturing run, and where it is made. The last one contains not only labor and raw material costs, but such difficult things as shipping, import duties, and tariffs.
One of the previous posts was from a guy in Canada who traveled to the USA and found that Kubota oil and filter parts in the USA were less expensive so he bought his spares stateside. I wonder why that difference in price? That ought to be one we could figure out.
If Good Luck beats Good Planning....then here's to the Lady!
rScotty
TMA (A49461)
TMA (A49461)
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
1990 Ingersoll Rand 185 Towable Diesel Air Compressor (A52377)
1990 Ingersoll...
U56 ELECTRIC FIRE PUMP (A51406)
U56 ELECTRIC FIRE...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
