What did I stumble into?
   / What did I stumble into? #11
Already have a 3rd function for the grapple. 13gpm. I'd feel more comfortable if I knew the specs this thing was capable of. I am not sure what happens if 13 gpm are applied to something designed for 5 gpm. Maybe it just spins faster...maybe it make many little pieces of itself?
ac
It will over rev at flows higher than its spec. Just run the tractor slower to reduce pump output flow to the correct range. If you need to run the tractor engine fast for some reason while using the motor you would need a flow divider.
larry
Oh man, I am SO excited! I am going to temp hook it up to the 3rd function just to make sure it works. If it does, I'll have to figure out what to do with it. I could run it through the 3rd function and come up with some sort of bucket mount or SSQA mount...or I could go "nuts" and make a backhoe mount and plumb in a rear remote that could double for a future thumb!
Who's excited? THIS GUY! :thumbsup::thumbsup::thumbsup:
   / What did I stumble into? #13
You might want to run some fluid through it before you hook it up to your tractor hydraulics to clear out any crud in it. Do like they said pour some fluid in it and rotate it by hand to pump the junk out. No sense in introducing more contaminants into your tank.
2010 BMW 328i Sedan (A56859)
2010 BMW 328i...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
PALLET TOTE OF MISC PARTS (A58374)
PALLET TOTE OF...
FENCE PANELS (A58214)
2015 Hoist P360 36,000lb Straight Mast Diesel Forklift (A55973)
2015 Hoist P360...
KMC RIPPER SHANKS, MOUNTING BRACKETS & WEAR STRIPS (A52708)
KMC RIPPER SHANKS...
