What diesel trucks to avoid
   / What diesel trucks to avoid
Thanks to everyone for the feedback. Chances are, I'll wind up doing nothing, but I always like to look. If I did make a move, I'd wind up with something that I don't really want. As much as I would want a pickup, it'd be too expensive to get one that can tote a carseat around. So, I'd wind up with a 99 Suburban or an Excursion. I'd actually probably quite enjoy a diesel Suburban, but it still wouldn't be a truck. I guess if I happen to run into someone on the street who wants to do a straight-swap, I'd do it. But, that won't happen. :)
   / What diesel trucks to avoid #32
if you're still looking, a guy my friend works with has a '97 regular cab 4x4 Ford F-250 with the 7.3 powerstroke in it. he told me the guy is the original owner of the truck and that it only has 153,000 miles. Body and paint is in great shape according to him, and it's two tone blue I think I remember him saying. the truck is also a 5-speed manual. guy is asking $9,000 but my friend told me if someone showed with $8,500 the truck would be theirs with no problem.
   / What diesel trucks to avoid #33
One I've noticed about the Dodge Sprinters that FedEx uses locally is that they already have a fair amount of rust showing on the bottom of the rear doors. This is central ohio where road salt is used, and I suspect they have a fair amount of miles on them, but I would expect that on a 10 year old vehicle not on a 3 year old vehicle.
   / What diesel trucks to avoid #34
Interesting and something I would not expect from the one's I see here in California and Mercedes being from Germany where they also salt the roads.
   / What diesel trucks to avoid #35
It's always difficult to say how a fleet vehicle gets cared for compared to an individuals... some companies may be spot on on regular washing & maintenance, where others... well it's a 3/4/5 year turnaround on them.
In Maine we are using that god-awful CaCl on the roads and it's chewing everything up: my 2005 Altima with 35000 miles had the right rear brake pad completely eaten away in 3 winters, and already the oil pan has some spot/pack rust showing... I wonder if automakers have conspired to get that stuff on the highways?:confused:
I am sure regular washing & upkeep plays a factor on a 3 y/o vehicle going punky so fast... but the de-icing offerings sure aren't helping any!:mad:
Oops, diesels to avoid: GM 6.2, 6.5, 2003-2004 Ford 6.0 without headstuds/gaskets/coolant filters!:D
   / What diesel trucks to avoid #36
I take exeption to avoiding the 6.2 and 6.5L diesels. While not near as strong as the PSD or Cummins, With a little research and proper build up/maintance, my 6.2L has been dead nuts reliable. Main issues are poor fuel filtration, and guys thinking they can flogged the crap out of them like a cummins and not have it break. When I had my fresh 6.2L built for my truck, I had ARP head studs, ballanced bottem end, main stud girdle, and Mahle pistons that are made for turbo use, but also lessing cylinder wall scuffing. I can find parts at most autoparts store when I am on the road, cheap to fix and I get a solid 23-24mpg running light on the highway with the cruise on. The main issues on the 6.5L were the electronics and those can be dealt with effectivly. If you want a 6.5L suburban, check out the diesel page and other other GM diesel forums. Also you willl want the one issues of Max Torque Magazine as it shows how to build a 6.5L td powered suburban towing rig that can hang with a second gen cummins or first gen Powerstroke diesel without overheating and blowing up. Now the old 5.7L olds v8 diesels are quite a boat anchor, but most are long gone now and they were only avaible in the 1/2 ton trucks. You can actulay get a 6.5L block from GEP now that has all of the weaknesses fixed now. The block and heads are cast by Naviastar now, no longer have the cracking issues they were once prone to. The HP is turned up now as the Military needed the extra HP for the up armored hummers in Iraq but also needed the engine to last. I prefer the older diesels that have no electronics on them, GM 6.2L or 6.5L, Ford 6.9, 7.3 idi non turbo, and the 12v cummins. Let us know what ya get. Mike
You don't have to defend it just because you own it. :D Although, I have to say that seeing your avatar there, your opinion now outweighs EVERYONE else's! I miss my Wheel Horses. :(
   / What diesel trucks to avoid #38
Crash101 said:
I hear and read often of remarks concerning the Dodge body and transmission problems and certainly believe the reputation is well deserved. That well deserved reputation however is based on earlier models and does not apply to the current generation Dodge truck. To suggest this model Dodge is in any way inferior to a GM or Ford (both very fine trucks) is to confirm one probably doesn't know what he/she is talking about and is speaking based on opinions or influence from someone else. After 40 years of buying a whole lot of vehicles (never a Chrysler product until 2002) if I were to buy a new truck and intend to work it for a million miles, I guarantee that smooth riding GM or that nice looking Ford would be second and third choice. My bias is not without a good deal of personal experience, much of it from those other brands including a few I looked forward to being rid of.
The Dodge five speeds used to "lose" fifth gear when a nut came loose and the gear worked out of the splines. Standard Transmission for one makes a fully splined shaft that cures that. The torque monster is tough on an automatic but there are aftermarket cures for that as well.
My 97 5sp called for Castro Syntorq fluid which was pretty pricey when I last purchased some. I had run Amsoil for awhile but it came out kind of milkey when I did the 5th gear fix so I went back to Syntorq.
I bought my 97' used in 99' and washed it maybe once or twice a year if it needed it, lol! Up until I moved last winter, it was always covered in PA salt. True, I have a couple of rust spots but overall the body is pretty solid considering. I don't feel that it is any worse than any other make.
No matter what I tried, my carpet still gets wet (another Dodge quirk) so I ignore that as well. Overall, I figure at 215k, the truck owes me nothing.
   / What diesel trucks to avoid #39
I am in no way a Ford man when it comes to trucks, but I have to say I know a guy who bought one of the original 7.3 powerstroke diesels and it now has over 400,000 on it and the only major work was a new transmition at 275,000. He is a farmer and uses the heck out of it. I rode in it the other day for a short distance and it still runs very well. I asked him when he was going to trade it off and he told when he wears it out. I have a friend who bought one of the new 6.0 diesels and was sick. He ended up selling it and buying and old 7.3.
   / What diesel trucks to avoid #40
Cummins 5.9 is a good engine. Problem is finding one with less that a gazzion miles on it. Most are worked long and hard. Neighbor puts 30-40,000 on per year and has for 10+ years. It's still purring. Auto trans was weak in them. Not the trans' fault as they pack a lot of torque. The manual trans was good.
The Later Ford 7.3's are good too. The early 6.0L has had a lot of problems documented and is the largest warranty black hole ford ever had. The 6.4l is supposed to be pretty good, but emissions kill the mpg's. Folks I know with steeper gears get low teens to low double digits empty. One guy traded in a V10 gas for a 6.4 and LOST 2 mpg. Talk about pissed. The 6.4 is already obsolete. No matter how good, that would scare me away.
The 2001-2002 Duramax had injector issues. The 2003-2004.5 has them to a lesser degree. I have a 2003 and it is on original injectors and has returned 17.6 mpg overall mpg since new. Empty on the freeway it gets 21-22.5. It tows 10k about 5000 miles a year. Get's 11-13 towing with speed and wind being the big factor, the weight is nothing. Trip to yellowstone last year (2400 miles+) averaged 20.6 mpg and that's with western freeway speeds. 75 mph.
The rest of the duramax family is quite good, but with more power and more emissions stuff, mpg's are down. The newer ones with the 6 speed allison get some back, but the mpg kings are the ones with the weak injectors. Go figure. The replacement injectors are "supposed" to be better. Still, you can leverage that into a 2k price drop and store the money. You can do the injectors but it's a 8 hour chore.
If you can get a duramax with the 6 speed manual those are supposed to be 1-3 mpg better than the allison, but don't hold your breath on finding one.
2007 Ford E-450 Super Duty 16ft Portable Command Center Office Truck (A55852)
2007 Ford E-450...
2006 TK Equipment CM9 Towable Concrete Mixer (A55851)
2006 TK Equipment...
2014 PETERBILT 388 (A55745)
2014 PETERBILT 388...
SHOP CART W/CONTENTS (A55745)
SHOP CART...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A56129)
2020 FREIGHTLINER...
2022 WESTERN STAR 49X TRIAXLE (A55745)
2022 WESTERN STAR...
