thanks again, everyone for posting.   Here's an update, but hotter rear brakes and brake booster to the floor issues are still there.
Regarding rear brakes hotter than front, I have cleaned and relubed all 4 brake caliper pins, so I know the calipers slide freely. all the pads still look good. I've flushed the fluid out of all lines, and bled the brakes 3 times by the 2 man method. The rear brakes continue to get twice the temp of the front brakes after several stops, but not where I can smell them during normal braking. the brakes are not dragging, as on a long drive with a gradual slowdown there is no heat to speak of on any brakes. I called the local chevy dealer and talked to their truck shop foreman. He said in his experience the rear pads wear out before the fronts on these work trucks, but he did say that they usually are carrying some load. That indicates to me the rears do a bigger share of the braking on this truck than conventional wisdom suggests. I could never find a proportional valve, so if it has one it must be with the ABS valves.
regarding the hydroboost, I didn't ask the dealer, as I felt I had already used up my free advice allotment. Saturday, I stopped in at a used car dealer and tried the brakes on a 2006 K1500HD just like mine (mine is 2003) and the brakes went right to the floor just like mine. one rainy day I went out on a rural road and did a few panic stops, and could feel the ABS working.
I think I've gone as far as I can, and see no change since I started this project.
