What do I need to know before buying fronts for a JD 4300?
   / What do I need to know before buying fronts for a JD 4300? #1
Taylorcraft078
Western NY - USA
green
Tractor is a JD 4300 4wd. I bought it with the house in May. When we looked a the place in February it was in the garage with a snow plow on it so I took the hint and got a decent price on it. Main uses are snow plowing the driveway, plowing my small garden, and hauling crap around. I have a front tire that keeps going flat - about 3-5 days. Both fronts are pretty worn so I am just going to put a new pair on. The tractor came with tire chains for the front. Current tires are 25x8.50-14.
What should I know before I get new tires? I don't need the best as the tractor will probably get less than 25 hours/year use but I also want decent grip for pushing snow. I also don't want to have to replace them from falling apart quickly.
What is a ballpark price for a pair of mounted 25x8.50-14 tires? I will pull them off the tractor and drop them off.
Dave
New/Unused 2025 STSD10 Seeder (A44391)
New/Unused 2025...
2009 INTERNATIONAL DUMP TRUCK (A43004)
2009 INTERNATIONAL...
Fleco 6T 50mm Main Pin Hydraulic Thumb (A42203)
Fleco 6T 50mm Main...
2004 Ford F-350 4x4 Utility Truck, VIN # 1FDWF37P84ED81730 (A44391)
2004 Ford F-350...
10'x20' Single Garage Metal Shed (A44502)
10'x20' Single...
(4) Foam Filler Tires and Wheels (A44391)
(4) Foam Filler...
