What do these numbers mean on a New Holland?
   / What do these numbers mean on a New Holland? #1
tobacco chewer
1996 New Holland 6610
On the right side of transmission on the mounting boss is these numbers ( EM4H4C) (*6L23B*) ( *355273M). On the right side of engine on the pan rail in the center of engine is these numbers ( *NA639484*) (6J03) ( 82850639). Can anyone tell me what these numbers means? I am trying to figure out what size & year my tractor is. The person I brought it from didn"t know. If no body know maybe can tell me a site on internet where I can find out. I been to tractordata,com with no luck. Any help will be appreciated. Thank you. My Email address is bigdave1112@hotmail.com. Thank you.
   / What do these numbers mean on a New Holland? #2
6L23B
July 23, 1976 or 1986 or 1996 or 2006 production, afternoon shift.
   / What do these numbers mean on a New Holland? #3
6L23B
The unit code could be from 1966 as well, but if it is properly badged as a New Holland, it is a 1996. Unit codes went by the wayside prior to 2006. I don't have all the model and serial number info here at home, but it looks to be a 4 cylinder Mexican-built S-series tractor (5610S, 6610S, 7610S) from 1996.
The person I brought it from said it was a 1996 or 1997 New Holland 6610. I change the hydraulic fluid & filter. It just held 15 gallons hydraulic fluid. According to TractorData a 6610S hold 56 gallons hydraulic fluids. Any more information you can give me will be a big help. Thank you.
   / What do these numbers mean on a New Holland? #5
It is likely to be a 1996 6610S. Always use the 'S' when describing the tractor, as there is a 6610 that precedes your tractor with many differences.
Tractordata.com is wrong often enough so as not to be trusted for more than casual use.
Thank all for the help? I think I may have to replace the hydraulic pump on it. The loader lift slow. It will not raise the front tires off the ground. I as want ing to make sure of the year & model so I can check the price for one. Thank you.
   / What do these numbers mean on a New Holland? #7
even with a new pump the loader will still be slow unless u have the dual pump set up which means there is one in the rear diff housing and a engine monted pump together they put out i believe 14 gpm but the one in the diff. housing puts out 8 or 9 and the engine mounted one puts out about 5 or 6
   / What do these numbers mean on a New Holland? #8
ditto what the others said.
remember.. 56 / 4 = 14.. so i take it TD was shooting for quarts.
my 7610s holds something between 13-15 gallons, depending on the sa hyds I've got hooked up to it.. so that sounds about correct.
ditto again what rick saidf about always refering to yuor machine as a 6610 "S" that makes a huge difference vs the 6610, and 6610 II models..
soundguy
What is the difference between a 6610S, 6610, & THE 6610 11? I am new to theses newer model tractors. I am use to the 50's & 60's 8N & the 600 tractor. Thank you.
   / What do these numbers mean on a New Holland? #10
all just and upgraded model of each other the first was a 6610 then upgraded the steering and called it a 6610 II then came the 6610 s which had a different fuel system and built in mexico then the next 6610s had a different engine because emision controls and also a different filters because of emision and then the last 6610S had a different rear diff. because they used a larger hyd pump and had the emission controled engine
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Grove TMS 9000-2 115 Ton Quad Axle Crane Truck (A60460)
2019 Grove TMS...
2008 INTERNATIONAL MA025 FLATBED (A55745)
2008 INTERNATIONAL...
McFarlane 4025 Reel Disk (A59814)
McFarlane 4025...
2020 FREIGHTLINER M2 NON CDL 26FT BOX TRUCK (A59575)
2020 FREIGHTLINER...
