Tiller What do think of First Choice tillers.
   / What do think of First Choice tillers. #1
hdannyh70
I am wanting to buy a new tiller. I like the first choice tillers, how well do they work and hold up.
   / What do think of First Choice tillers. #2
A great question to ask about tillers is:
Where can I purchase replacement tines from?
A limited source for replacement parts could be a problem down the road. I don't have any personal experience with FirstChoice, and don't know about their tine replacements, but you should know before you buy.
   / What do think of First Choice tillers. #3
I've had one for 2-3 years now and zero mechanical problems. I till the garden in the spring a couple of times, and after the crops are harvested I till it again.
I've tilled some lumps from the yard and a patch or two upon the hillside that was a bit rough from box blading.
   / What do think of First Choice tillers. #4
I got my FC at Sweet Tractors, he's on the board and I'm sure if'n a tine is needed Ken can hook you up.
   / What do think of First Choice tillers. #5
I've had my FC tiller for about the same time as theboman and I have had great luck with it. The people at SweetFarm are excellent to work with.
   / What do think of First Choice tillers. #6
I have used a FC tiller for the past two years. I am very satisfied with the performance and I have had no problems.
If you buy a FC you may want to make a set of dollies for it. They are simple to make and they make it real easy to hookup and remove. I am sure that the same system will work on other tiller brands also.
John
   / What do think of First Choice tillers. #7
Nice Dolly, JWE: At first I thought that the pin was to hold the tiller end on the dolly until you have it attached to your 3ph and are ready to raise it; but now I'm not sure; How does the pin lock?
   / What do think of First Choice tillers. #8
MadDog.. The pin just slides over the skid. The dollies are very easy to install and remove. I can push my tiller around my garage floor with one hand.
Attached is a better picture of the retaining pin.
John
   / What do think of First Choice tillers. #9
Good idea JWE. I think I will have to do something like that too for the new tiller I just got.
   / What do think of First Choice tillers. #10
Thanks, I think I understand it now. The pin is long enough so that it goes through both sides of the angle iron and over the tiller skid that is resting on the dolly. That's a neat idea.
Looks like it would be pretty easy to make with just a bit of cutting and drilling on the channel bar, which I think I can handle with a band saw and drill press.
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
45'x25' Metal Garage (A53316)
45'x25' Metal...
2017 Ford Transit 350 Handicapped Van (A53422)
2017 Ford Transit...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A55788)
2018 Ford F-150...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55301)
2017 KINZE...
Self Dumping Hopper (A53316)
Self Dumping...
