What do you guy's think? CK30
   / What do you guy's think? CK30 #11
Re: What do you guy\'s think? CK30
If you don't hear back from them within a reasonable amount of time, call them back. Sometimes things get pushed aside. Gerard
   / What do you guy's think? CK30 #12
</font><font color="blue" class="small">( I've asked my dealer about this and he said I don't need worry. Should I contact Kioti and make sure? Thanks for all your help!)</font>
If you'll look at the CK30 on Kioti's site, you'll see that they only recommend the KB2365 and KB2375 for that model. If something breaks, the dealer's words have no weight. All warranties state that nothing is included in the warranty other than what is stated in that warranty. If the BH is not designed for that model, without written approval from Kioti/Daedong to use the larger BH, you'll be out of luck on warranty if the BH is the cause of damage to the tractor. Sure, the dealer may be able to get you taken care of, but then again, he may not, and you'd have nothing to stand on without written approval. John
Kioti called back and stated if the backhoe caused the problem it will not be covered. What do you guy's think can tractor handle that hoe?
regards
Glen
   / What do you guy's think? CK30 #14
The problem is Kioti's answer is really vague.
You could be mowing, (not have the BH on) and the rear end come apart. Even though the BH was not attached they may say that it caused the rear end to come apart. /forums/images/graemlins/crazy.gif
I think you get what I'm saying.
I would go with the smaller BH.
RedDog
   / What do you guy's think? CK30 #15
</font><font color="blue" class="small">( Kioti called back and stated if the backhoe caused the problem it will not be covered.
What do you guy's think can tractor handle that hoe?)</font>
There's your answer. Unless you want to risk possible damage........ Gerard
Thanks guy's
   / What do you guy's think? CK30 #17
</font><font color="blue" class="small">( Kioti called back and stated if the backhoe caused the problem it will not be covered. What do you guy's think can tractor handle that hoe? )</font>
Do I THINK it can handle the hoe? Yes. Would I put it on the tractor and take a chance on it voiding the warranty? NO. There are too many things that can happen, and a BH puts a lot of stress on a CUT. Even with a subframe, it'll make the tractor jump and dance at times. Go with the 2375 or step up to the DK35 and get the 2385. I imagine you'll be satisfied with the 2375/CK30 combo. John
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2004 IC Corporation 3000IC School Bus (A55852)
2004 IC...
2017 MEC 1930SE 19ft Scissor Lift (A55851)
2017 MEC 1930SE...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
2024 John Deere 8R 410 MFWD Tractor (A53485)
2024 John Deere 8R...
2011 Club Cadet 13WX90AS056 42in Riding Mower (A55853)
2011 Club Cadet...
