What Do You Think about Steering Wheel Zero Turns?
   / What Do You Think about Steering Wheel Zero Turns? #11
I have a Cub SZ60 Tank with the steering wheel and it is fantastic on hills. I've used conventional lawn tractors/garden tractors/zero turn tractors/and conventional zero turns, but the 4 wheel steering blows them all away. It's incredibly stable even on side slopes, I mow a section that is a bit uncomfortable angle, and the machine performs flawlessly, even turning uphill on a sideslope.....the steering wheels are so much better than lap bars in my opinion.
Looks like about the slope on my pond bank.....back side.
Couple of questions.
First, I noticed you are running turf tires. You have no problem holding on that bank with the grass wet?
Second, Am I seeing a pair of foot brakes and assume that they are independently connected to each rear like a regular tractor?
Third, You said 4 wheel steering. Are you considering independent rear braking capability a steering mechanism? Makes sense if you do.
I know what CC used to look like but I have seen yellow next to red and orange and green and black and to me what they offer looks right in line with the times.
Thanks,
Mark
   / What Do You Think about Steering Wheel Zero Turns? #12
Thanks,
Mark
Hi Mark -
I typically wait for the grass to dry out to mow..I have mowed with grass a bit wet, but on that particular slope I would c r e e p along to avoid sideslipping. Perhaps more aggressive rears would make a difference.
The twin pedals on the right are hydro pedals, forward/reverse. Once you let off the pedal, unit stops. Left pedal is deck raise. My only criticism of the unit is not having a foot brake. There is a parking brake by the seat you can use that de-links the drive pedals immediately, a foot brake might be a bit more convenient. Not a big issue IMO.
The unit has power steering.....and it is literally a 1 finger operation. So with using linkage in a turn, and the independent rear pumps also compensating for the turn, you effectively have 4 wheel steering.
I will admit I am biased in choosing of color and have not done any research or test drives on other brands. I've ran CC for 20 years now with great success. I know they have issues with certain models as does every manufacturer.
I'm sure other brands are very competitive with this level of mower. I do know CC was the first to introduce the steering wheel ZT, and others are now following....unsure if CC has a leg up on technology, but I will say on the machine's datapplate they list around a dozen patents regarding the machine.
At 1300 lbs, it is definitely a commercial duty mower. The frame is 1/4 true steel, the strong engine and HD drive pumps are just what I need for my sloped lawn.
Hope this helps!
   / What Do You Think about Steering Wheel Zero Turns? #13
Hi Mark -
Hope this helps!
Yes. Thanks. Seems like a good way to steer, both the wheel and running the pumps with your foot. 1300 # pretty much says it all on the thought that went into the design.....bang for your buck.
The reason for my curiosity is mowing my pond bank. I have a unit (conventional Husqvarna standard rider) that I modified to suit me and works well but always keep my eyes open for something better.
   / What Do You Think about Steering Wheel Zero Turns? #14
With the steering wheel, if you do a tight turn does the inside back wheel stop and leave a pivot spot in the grass or have they compensated for that kind of like doing a K turn?
2011 20ft. Anderson Lowbed Trailer (A56859)
2011 20ft...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2014 Kawasaki Mule 600 Utility Dump Cart (A55973)
2014 Kawasaki Mule...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
Geismar powered by Stihl (A56435)
Geismar powered by...
