what do you use Fluid Film 4 ?
   / what do you use Fluid Film 4 ? #11
I sprayed down my brush hog and rear blade and then wiped it into the finsh with a rag.
I have washed down the BH 2 times since it was sprayed and it still beads up like crazy plus it brought back the shine and deepness of the paint.
Good stuff.
   / what do you use Fluid Film 4 ? #13
Hey Duffster, I'll pass on the frying pan use!!!! :cool:
I use it for rustproofing stuff when I park it in the winter, such as the wood chipper, antique metal items just for dispaly etc.
It's also AMAZING for leather boots such as cowboy boots (not the fancy ones) and work boots. Soak them right down with it and let them dry off and you'll be amazed. Helps boots repel water and last forever.
Like the other fellas say, it's great for all sorts of stuff.
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
2018 Ford F-150 Crew Cab Pickup Truck (A53422)
2018 Ford F-150...
2019 Allmand Bros Maxi-Lite II 15kW S/A Towable Light Tower (A52377)
2019 Allmand Bros...
2005 Dodge Caravan Van (A54815)
2005 Dodge Caravan...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
