What do you use to lubricate the 3 point hitch assembly?
   / What do you use to lubricate the 3 point hitch assembly? #1
jodebg
Platinum Member
New Hartford, CT
Kubota B-2650
Wondering what is the best lubricant to use on the 3 point hitch assembly?
Recently read about a wet graphite spray...is this product better than other
to use on the moving parts on the 3 point hitch?
   / What do you use to lubricate the 3 point hitch assembly? #2
I am a wd-40 and duct tape person, myself.
Where do you use duct tape on the 3 point assembly??
   / What do you use to lubricate the 3 point hitch assembly? #4
Right or wrong...I use Fluid Film, it doesn't have the solvents that most spray lubes have so it lasts much longer. It's great for all linkages as well.
   / What do you use to lubricate the 3 point hitch assembly? #5
+1 on the Fluid Film.
Sent from my iPad using TractorByNet
   / What do you use to lubricate the 3 point hitch assembly? #6
+2 on the Fluid Film.
Also use it on the PTO spline.
   / What do you use to lubricate the 3 point hitch assembly? #8
Graphite would be the better choice, the other choice would be use nothing. Any kind of waxy or oily coating is just going to attract dirt which will work just like sand paper to wear out the joints faster than using nothing.
   / What do you use to lubricate the 3 point hitch assembly? #9
fluid film here. The best I have ever seen for this application. I also use it on the SSQA linkage up front.
   / What do you use to lubricate the 3 point hitch assembly? #10
I use the JD dry lubricant spray. It lubricates but stays dry to the touch so it doesn't attract dirt and debris.
Land Honor 84" 3 pt Disk (A50514)
Land Honor 84" 3...
UNUSED CFG Industrial XZ20R Mini Excavator (A47384)
UNUSED CFG...
International 133 6 Row Cultivator (A50514)
International 133...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A52128)
John Deere 1110...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
