What Else Do You Call a "Bumper Pull" Trailer?
   / What Else Do You Call a "Bumper Pull" Trailer?
I went the other way.. I have 5th wheel rails and had/have a reese 5th wheel adapter. I have removed it right now, and bought 'the goose' it's a gooseneck adapter that fits 5th wheel frame rails.. So I got the best of both worlds.
soundguy
That's the same set up that I have. Mine is a Reese brand gooseneck ball. My daughter calls it my "goose bump".
The 5th wheel rails are a bit of a pain to have in the back of the truck all the time, but if I'm going to have them anyway for the camper, I might as well avoid drilling a hole in my bed for a ball. For the amount of weight that I pull with my 1/2 ton truck, the rail and spider set up is great.
   / What Else Do You Call a "Bumper Pull" Trailer? #32
OK, one more tiny shot at humor;
It really doesn't matter WHAT you call it,
it won't come to you when you call it.
Ha Harr...
I have a Hillsborough aluminum flatbed on a 1 ton frame, it has the trap door with gooseneck ball installed.
All this works very well for me and has done so for over 6 years.
Having a full width bed over has been much more convenient than just a 4ft or so wide space between wheel wells.
So much easier to toss couches and stuff on from the side for casual furniture moves.
NO questions of clearance between the underside of the trailer and the top of the truck bed sides.
No tailgate to mess with - and forget it is still down until the first sharp turn after hooking up.
{If you see folk with gooseneck or mini 5th trailers and no tailgate - don't ask whu they took it off (-: }
When I tow I just flip the trap door open, back under the trailer, etc.
There has never been a "grease the dog" (which then greases the house) scenario.
From time to time I have been asked to move campers to/from seasonal sites for folk who don't know the difference between (mini)5'th wheel and gooseneck.
I like helping people out and once in a while it doesn't bother me if I spend a few bux and don't get it back.
I have no interest in obtaining insurance coverage for this and since these trips would typically cross State lines... to do it for anything more than exact out of pocket expenses would classify it as interstate commercial hauling. So insurance would be HIGH to haul a couple of other folks' trailers say 100 miles each way a couple of times a year.
OK, so I tried to figure out a rails set for one owner's hitch that she has - though she has no truck (Widow, long story).
There is no reasonable way to mount a (regular production) Reese - Drawtite turn-table over a flat bed and get to a workable pin height.
I looked at the various hitch adapters and converters, they all add too much height and/or require modification of the trailer - these are not MY trailers, so I'm not getting into that possibility.
Summary/Conclusion;
If you want a flat bed AND want to tow both goosenecks and mini 5th wheel trailers you will need to plan WAY ahead for this.
There is ONE hitch on the market that might do the job, but it is somewhere around $800, so I haven't investigated it to see what height it would end up at.
It might be worth it for someone who owns and uses both trailer types, but I don't.
   / What Else Do You Call a "Bumper Pull" Trailer? #33
I have always called them receiver hitch, ball mount, ball hitch trailers. :laughing:
But, bumper pull seems to be the commonly accepted description.;)
   / What Else Do You Call a "Bumper Pull" Trailer? #34
In holland, bumper pull trailers are referred to as "a tandem" to describe a tandem, "a hook-on" for anything single axle (but some call every light trailer a hook-on) and then we have a type of trailer you dont see as much in the USA: The light duty 2 or 3 axle turntable steered trailer. It gives great stability, both with high COG loads, crosswinds as well as cornering. Most folks cant back them up though, so use is limited to those who go to worksites with a skidsteer or mini ex behind a 4x4
In heavier trucks, there are opleggers (literally lay-on trailer, which is a 5th wheel semitrailer) also the turntable steered trailer, but the heavy truck mid axle trailer is called a wipkar (seesaw cart)
The gooseneck hitch is unknown in light trucking here: Its either the small 5th wheel, a 50mm ball hitch up to 3500kg, and the self locking muzzle coupling.
   / What Else Do You Call a "Bumper Pull" Trailer? #35
I have a specail hauler/tool box bed anyway.. has extra 50g fuel tank on xfer pump.. betweent hat and the tool boxes, there is no real useable space anyway.. so the rails are a non issue. I got enough room for some spare timber for jack stands and a spare tire and that's pretty much it. :)
soundguy
I've got to ask, what does "grease the dog" mean?
Speaking from experience... My dog rides in the back of my truck. When I have my "goose bump" installed in the bed grease will sometimes get on the dog from the ball.
My dog doesn't come in the house, but I can see how it would create domestic contention if he did when he was greased from the ball.
OPENATS ROTARY TILLER (A52708)
OPENATS ROTARY...
GAME FISHER 5HP OUTBOARD MOTOR (A58374)
GAME FISHER 5HP...
2018 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2018 MQ POWER...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
2025 40ft. High Cube Shipping Container w/ 1 End Door & 4 Side Doors (Est. Retail Value ($12,000)... (A59225)
2025 40ft. High...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
