What engine is in my New Holland TB110?
   / What engine is in my New Holland TB110? #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
I guess this is "after the fact" but I would just like to know what engine is in my tractor. When I bought the tractor, I was told by a dealer that it was the same engine that was in the Ford / New Holland 7610. Today, I was told by another dealer that it is the same engine that was in the 7740. Are either or neigher of these correct?
   / What engine is in my New Holland TB110? #2
You have 90 pto hp and 304 ci and the 7740 has 86pto hp and 304 ci. The 7610 also has 86 pto hp but 268ci. I would have to say it is the same size as the 7740. It could be a totaly different engine but the specs are the same.
Bill
   / What engine is in my New Holland TB110? #3
Here's what TractorData.com - information on all makes and models of tractors says
Manufacturer: New Holland
Fuel: diesel
Aspiration: turbocharged
Cylinders: 4
Valves: -unknown-
Bore/Stroke: -unknown-
Displacement: 304 ci [5.0 L]
Power: 110 hp [82.0 kW]
Cooling: liquid
Coolant: 13.6 qts [12.9 L]
Compression: -unknown-
Rated RPMs: -unknown-
Starter volts: 12
   / What engine is in my New Holland TB110? #4
the 7740 and 7610s used the same motor and the earlier 7610 had a smaller cubic inch motor. the tb100 is a fiat tractor and i believe it had a cat motor no for sure but i know its nothing like the 7740. the ts100 had the same motor as the 7740 and 7610s, and the 7740 and 7610s still had a ford motor
   / What engine is in my New Holland TB110? #5
The 7710 had a BSD 444T, the 7740 used the Genesis engine, the TB uses the NEF engine. The Genesis is the updated Ford /BSD design. The NEF is similar, it's a combination of a NH and Fiat (Iveco)
   / What engine is in my New Holland TB110? #6
My bad. Looks like a TB100 has a Genesis engine. Like a 7740.
Heavy-Duty 4-Wheel Rolling Warehouse Cart  74in x 32in (A44789)
Heavy-Duty 4-Wheel...
2024 40 ft. High Cube Shipping Container (A47484)
2024 40 ft. High...
2015 Nissan Murano SUV (A44572)
2015 Nissan Murano...
2025 Dig Master DM100 UNUSED Mini Excavator (A47484)
2025 Dig Master...
2011 Ford F-250 4x4 Ext. Cab Pickup Truck (A44572)
2011 Ford F-250...
2025 LandHonor LHR-GAC40Y 2-Stage Air Compressor (A47484)
2025 LandHonor...
