What equipment to mow a slope with?
   / What equipment to mow a slope with? #1
sendero
Grayson County TX
Kioti DK35
I have a pond with a 250' long dam. The front side of the dam is pretty steep,the back side a little less so.
There is no way I can use my Kioti DK35 on this. But I'm wondering what the right equipment would be. Right now I'm using a modified push mower (added 12" wheels :)" and it does the job but is it a grueling bit of work.
I've considered one of those DR field brush mowers, a low-center-of-gravity rider like a cub cadet or whatnot.
Like most things, I don't really want to spend thousands so I'm looking for ideas.
   / What equipment to mow a slope with? #2
How about a sickle mower??
   / What equipment to mow a slope with? #4
How about some pictures? If it's just a couple feet of pitch, then the sickle bar may be your best bet. But, if it's more than just a couple feet, I know something that may be able to help.
We once watched someone with a Steiner 4x4, articulating mower. It had dual wheels on all 4 corners. That thing was mowing stuff side-ways that I wouldn't even consider to mow straight up & down. On the Steiner, the mower is mounted on the front, which makes it very easy to see and to mow around stuff.
   / What equipment to mow a slope with? #5
Sheep or Goats!:D
Convert the slope to no maintenance with shrubs, flowers, grass and trees.:D
   / What equipment to mow a slope with? #6
My tractor - rated for crosswise on a 45 degree slope :)
PowerTrac - there is a forum here on them.
But then you said you did not want to spend thousands.
Ken
   / What equipment to mow a slope with? #7
I have the DR with both mowing "heads" and would not recommend it for slopes...it wants to keep veering off downhill if you work across. Nor would it work well (IMHO) up and down because there is no engine braking and the brake is not designed for this ...and, anyway, up and down is a lot of wasted effort on something long and relatively low like a dam.
   / What equipment to mow a slope with? #8
It might be worth your time to look at roundup for the slope and then plant a low growing ground cover like vetch or clover. You won;t have to mow it at all then.
   / What equipment to mow a slope with? #9
I'll second the negative on the DR- I hate it on slopes. I actually went back to using a hand-held string trimmer- nearly as fast and a lot easier on me.
Hmm... maybe I should sell the DR. I don't think I used it once last year.
   / What equipment to mow a slope with? #10
That sounds like the best advice and overall least costly solution. Just watch out for erosion until the new cover is established.
2015 FREIGHTLINER CASCADIA (A53843)
2015 FREIGHTLINER...
2004 Chevrolet Silverado 2500HD Service Truck (A53422)
2004 Chevrolet...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2000 Mercedes-Benz S-Class Sedan (A53424)
2000 Mercedes-Benz...
2014 SHOP BUILT  DISCHARGE MANIFOLD (A53843)
2014 SHOP BUILT...
230112 (A53422)
230112 (A53422)
