What 'grade' are hitchpins?
   / What 'grade' are hitchpins? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I am thinking of making some hitchpins that are longer than commercially available and it occurred to me that they might be hardened as in grade 5 or grade 8 or whatever. It never got thought about but I just assumed they were just cold rolled steel as in grade 2. Seems a harder grade would tear apart the drawbar hole that would likely be just plain old barstock and grade 2 ? Anyone have any ideas about this?
   / What 'grade' are hitchpins? #2
Drawpin hardness varies more or less with price. Generally, yellow zinc plated pins are soft and those with black oxide fiinish are quite a bit harder. How soft, how hard? Can't answer definitively.
   / What 'grade' are hitchpins? #3
I think the softest hitch pins are Gr4 -- the ones with the swinging handles. I prefer that form, altho I wouldnt mind them being harder like the ones with red or blue rigid handles.
larry
   / What 'grade' are hitchpins? #4
good ones are definately hard, twisted more yellow pins into pretzels than I can count. A325 bolts work pretty good, they are better than the yellow pins, mild steel will not hold up to heavy use. I haul baler and hay wagon, or chopper and forage wagon. Mild steel may be OK if you are hauling a small implement or something light.
   / What 'grade' are hitchpins? #5
   / What 'grade' are hitchpins? #6
I weld a 1.5" lock washer on the head of a grade 8 or a Supertanium bolt to make a hitch pin. We have bent others but never my homemade pins.
I don't mind using a harder grade such as an 8 but I pull heavier tillage things that slop around or bounce and don't want to destroy my drawbar in an afternoon. If that black TSC pin shown above (and below) is grade 5 i guess that's what to go with?
http://www.tractorsupply.com/hitch-pin-1-in-dia-x-7-1-2-in-usable-length-0269078
Any thoughts now?
   / What 'grade' are hitchpins? #8
My dad has had the same drawbar on his tractor for 50 years and he uses grade 8 pins.
   / What 'grade' are hitchpins? #9
probably something like 4140 chromoly would be good, it is stronger than mild steel, but not all that hard. 4140L if I remember right has lead in it and is a little easier to machine and probably even softer.
flooring (A55758)
flooring (A55758)
GEHL RT175 GEN 3 SKID STEER (A52707)
GEHL RT175 GEN 3...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A53422)
2015 Ford F-450...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
2016 John Deere 17 Mini Excavator (A47477)
2016 John Deere 17...
