What grade shear pin in woods bush hog
   / What grade shear pin in woods bush hog #1
cspot
My FIL has an old 6' Woods Bush Hog. Model 70 I think. Anyway it has a 7/16" shear bolt in it. I broke the shear bolt the other day when using it. I bought some grade 2 bolts to put in there. Now they break when you hit almost anything. What grade bolt should it be?
   / What grade shear pin in woods bush hog #2
If you have the old bolt check the head it will be marked as to the grade.
   / What grade shear pin in woods bush hog #3
If you have the original bolt, look at the head markings then google for "Bolt Head Markings" or "Bolt Grades". You probably won't see a grade number, but you will see a symbol or symbols.
I'd guess it's a Grade 5, but make sure you know which grade it must be. If necessary, call Bush Hog and ask them (but you'll probably need the model number).
Unfortunately the bolt head was gone when it broke. The bushhog is at least 30 years old, but is still in good shape. Most bushhogs I have seen use a grade 2 bolt 1/2" in diameter. This is 7/16" so I wonder if it is a grade 5 bolt.
   / What grade shear pin in woods bush hog #7
I will have to get the exact model number, but the bushhog is at least 30 years old so I don't know if it will be online or not.
Without the model number, you won't get reliable help here, either.
   / What grade shear pin in woods bush hog #8
This is not rocket science here fellas. Most likely it was designed for grade 2 or grade 5 bolts. Suggest you start out with a grade 2 bolt and run it for awhile. If it doesn't shear right off (or start showings signs of being cut into) with normal use, then run it like that. If it seems to shear excessively (without hitting immovable objects) and/or does show signs of the shafts cutting into it, then you might want to consider replacing it with a grade 5 bolt.
   / What grade shear pin in woods bush hog #9
Ditto. I wouldn't waste any time chasing down a thirty year old manual.
2016 Chevrolet Malibu Sedan (A44572)
2016 Chevrolet...
2015 International ProStar Truck, VIN # 3HSDJAPR0FN618550 (A44391)
2015 International...
2018 Ram 2500 Utility Truck, VIN # 3C6UR4HJ3JG269058 (A44391)
2018 Ram 2500...
1999 Volvo VN Truck, VIN # 4VA7BBJF7XN770864 (A44391)
1999 Volvo VN...
Heavy-Duty 4-Wheel Rolling Warehouse Cart  74in x 32in (A44789)
Heavy-Duty 4-Wheel...
New/Unused 7ft Workbench (A44391)
New/Unused 7ft...
