What Grease and How Often: Trailer Hubs
   / What Grease and How Often: Trailer Hubs #11
This might sound a little strange, but could it be that when the hub warms up with travel and expands the buddy loosens up a tad and falls out?
   / What Grease and How Often: Trailer Hubs #12
Not sure Mike. I have literally towed over 100 trailers probably over 100,000 miles and only lost one. Are you sure you are using the right size? There are a few sizes and 2 are very close, like 5/100th inches different. Also do not over grease them. This is common. All you should be able to do is rock the pressure plate a little with 2 fingers. Too many people fill them with grease 100% full and either lose them or blow the rear seals out.
In the end I bet you have the 2.04 units and the 1.98 is just not enough bite. I installed some 1.98 units on a bass boat and they felt loose so I tried the 2.04 and they were too tight but a little dressing with a file to basically remove only the chrome from the mounting area and they went right on nice and tight.
- Harbor Freight Tools - Quality Tools at the Lowest Prices
Chris
Thanks Chris. I think I'll put a micrometer on the hubs and possibly try using the 2.04".
Sounds reasonable to me.
   / What Grease and How Often: Trailer Hubs #13
I really think this is your problem. If not its your fix. I would make the 2.04 units work like I had to do on the Bass Boat I mentioned earlier. Good way to check them for tightness is with a good kick from the side. If it move its too lose.
Chris
JCB 409T4 WHEEL LOADER (A52707)
JCB 409T4 WHEEL...
JOHN DEERE BA84 WORKSITE PRO ANGLE BROOM (A54757)
JOHN DEERE BA84...
UNUSED FUTURE SF60 60" HYD SIDE SHIFT FORKS (A57193)
UNUSED FUTURE SF60...
2007 International 4300 (A53314)
2007 International...
2017 Kenworth T400 T/A Aquatech B-15 Combination Sewer Jetter Vacuum Truck (A55852)
2017 Kenworth T400...
Mohawk TP-15 15,000lb Two Post Auto Lift (A55852)
Mohawk TP-15...
