what grease on PTO shaft?
   / what grease on PTO shaft? #1
44trxfun
western NY
MF GC2300
My mid-mount mower shaft is getting a bit dried out. What grease do you all use on your PTO shafts.
   / what grease on PTO shaft? #2
If you're just talking about the splines - I just grab a dob out of the grease gun. Other than sliding the shaft on or off the splines - there is no constant mechanical friction movement with the shaft during use (not like a bearing or some sliding movement) so as long as it stays on the shaft I'd think any reasonably heavy wheel grease or lube would work.
If you're talking about a u-joint then that could be a little more fussy.
   / what grease on PTO shaft? #3
I asked the same question after I cut the PTO shaft on my post hold digger to length. Of course I got that durned thing all covered with dirt and muck as I was cutting and testing it. So I wiped it clean with a bit of diesel and went to the parts store for some grease.
They said "any old grease" so I bought a little tub of wheel bearing grease. Slapped a handful on it and put it togather. Seems to work fine.
   / what grease on PTO shaft? #4
I agree with the others. if I need to generically grease something small, I use a squirt of grease from my grease gun ( which is loaded with NH 'blue' grease ). If i need a large amount of 'non-specific' grease, I dip my hand into my 5lbs tub of axle grease I have and rub it on whatever...
Soundguy
   / what grease on PTO shaft? #5
I think that most any grease is better then none at all, just don't over-do a good thing.
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
2008 NEW HOLLAND B95 BACKHOE (A51242)
2008 NEW HOLLAND...
90018 (A48082)
90018 (A48082)
UNUSED FUTURE MINI SKID STEER HYD 4IN1 BUCKET (A51244)
UNUSED FUTURE MINI...
19011 (A48082)
19011 (A48082)
Caterpillar D5K LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K...
