What grease?
   / What grease? #1
needmoredirt
Country of TX
L2501HST4WD, BadBoy ZT, JD 125, JKU Rubicon
Got the kubota kool-aid from the jungle outfit.
Had to question, new grease from the dealer was red and way stickier, nothing like the black stuff I got.
Zerks are kinda off, electric green gun doesn't always play well w/offsets, a secondary issue to address.
Thoughts?
   / What grease? #2
:unsure:
   / What grease? #3
Lucas green heavy duty and a lock-n-lube tip on a pistol grip grease gun is what I use....;)
   / What grease?
lock-n-lube $25, I've seen it.
Maybe twist the zerks a bit too.
Rocket science I tellya ;)
I'll look at lucas, thx.
   / What grease?
OK. $35, I bit.
OTW
   / What grease? #7
Lever gun with a semi bent ridgid pipe. Very very early do I need to get the pistol grip flexible hose gun out. My hands are thanking me.
   / What grease? #8
I buy my grease in 120 pound open head drums and I only buy synthetic grease, not the black clay based crap. Only thing that stuff does is clog up zerk fittings. Like everything else in life, you always get what you pay for.
Additionally, with most quality grease couplers, you can loosen the collet end to release the coupler from a fitting if it don't want to come off. Cheap couplers are one piece. I bulk load my lever guns and they all have clear polycarbonate barrels on them so I can see when they are running low. Finally, I carry a lever gun in the tool boxes on each of my implements as well.
If I'm up near the shop, I'll use my air greaser but if not, I use a lever gun. I realize not everyone can afford an ARO air greaser but I can.
   / What grease? #10
My philosophy about grease in general is so long as it's not clay based, it's all good and far as Amsoil is concerned, if you want to pay for a name, have at it.
   / What grease? #11
Green grease with Milwaukee m12 and a lock n lube on the end
Curse myself for waiting so long to go this route
   / What grease? #12
Harbor Freight sells a clone that is a lot cheaper....lol Probably made in the same Chinese factory as well.
   / What grease? #13
Are you sure about synthetic grease not being clay based? Maybe it is synthetic oil, not a synthetic carrier.
   / What grease?
I'll start w/lock thing, in hand ;)
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
2019 CATERPILLAR 246D3 SKID STEER (A60429)
2019 CATERPILLAR...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Unused 2025 CFG Industrial MH12RX Mini Excavator (A59228)
Unused 2025 CFG...
