What happens if motor rpms are too high
   / What happens if motor rpms are too high #1
OutbackL130
chickamauga
L130, 420
I have a hydraulic ironworker runs off a 3 hp 230 volt 3 phase motor that is rated 1700 rpms. What I wanna do is swap in a single phase 5hp motor, but I'm seeing its rated 3400 rpms. How would this affect the hydraulics?
   / What happens if motor rpms are too high #2
If yours is anything like mine, the operation would be twice as fast. I wouldn't like that. I'd look up the specs on the pump and see if it's in range. My ironworker is by Edwards and is single phase. You could change the pump to a lower volume to compensate.
   / What happens if motor rpms are too high #3
Do you only want to use what you have or can you use this motor?
5 HP 230 VAC 1740 RPM MOTOR
If you motor is not direct coupled, you could use belt and pulley or chain.
CAT 973 Crawler Loader (A47477)
CAT 973 Crawler...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A55301)
Adams Load Out...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A54865)
IMPORTANT PLEASE...
Portable Restroom (A54865)
Portable Restroom...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
Giyi 72" Mulcher (A53316)
Giyi 72" Mulcher...
