MacandTosh
- Joined
- Dec 17, 2020
- Messages
- 5
- Tractor
- Row Crop
Does anybody know what happens to a pressure compensated piston pump in the regime of 0 RPM and minimum RPM, aside from heating issues or inefficiencies?
Specifically:
If I want to accelerate the RPM of the pump from 0 to say 1800 RPM (the max RPM of the pump), that means I will have to pass the regime of 0 to, say 500RPM (500 RPM is minimum recommended RPM). If I set the max system pressure to 2000 PSI, what will happen to the pressure (and in this case the torque to the motors) when I'm passing through that regime?
The pressure is most likely going to spike up after a rotation or two since the fluid is not easily compressible but will go back down and up I'd imagine.
I'm anticipating that when my pump's RPM is lower than 500 RPM and my vehicle is moving forward, the motors will be slowing down my acceleration since my motors will effectively be pumps.
But will this severely damage the pump? I don't plan to run it in this regime that often.
			Specifically:
