What happens??
   / What happens?? #1
LD48750
Veteran Member
SE, MI
Ford 1510 Mahindra 1526
What happens when you put a 5/8" belt on/in a 1/2" pulley?
Electric PTO clutch running a Mid Mount Mower.
   / What happens?? #2
It may cause the entire tractor explodes into 10,000 pieces killing everyone within 100 feet. Other than that, it may wear out a little quicker and not be able to transmit as much torque because of the reduced contact area between belt and pulley.
   / What happens?? #3
1/16th hangs over each side. Will it rub anything? Is it the same type of belt? Same lenght? Just 1/8" too wide?
   / What happens??
Nothing that I can see. Same old belt, new clutch & pulley.
If that happens, I guess I'll have nothing to worry about.
   / What happens?? #5
You should be fine.
   / What happens?? #6
Trying to logistically think thru the question. Two things come to mind.
1. It may try to come off.
2. It may slip because of less friction.
   / What happens?? #7
I did that once and the belt looked like
confetti all shredded to crap. The belt
should always be just slightly inside the
outside edges of the pulley unless you
like buying and replacing belts
willy
   / What happens??
willy
Thats not what I wanted to hear.
Now when the new clutch gets here I'm going to have to see if I can exchange it.
Thanks for the info before I make the new part un-returnable.
   / What happens?? #9
Not sure how logistics figures into this equation.
Use the belt and let us know how it works. I think it will be fine.
   / What happens?? #10
Ummmmm,,,,, logistics as in the compatibility of two physical objects. The same logistical thought used to determine that a larger belt is needed in a specific application. Or a smaller belt needed in a different application.
If there were no logistical thought used all belts would be the same size.
Maybe we have differing definitions of logistics? :)
1996 Monon 45X96 Dry Van Trailer (A46877)
1996 Monon 45X96...
53ft rollback (A44571)
2013 Ford Taurus AWD Sedan (A44572)
2013 Ford Taurus...
80in HD Tooth Bucket with Side Cutters (A46877)
80in HD Tooth...
2018 Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A46877)
2018 Kubota BX2680...
2008 Ford F-250 4x4 Reading Service Truck w/ Liftgate (A44571)
2008 Ford F-250...
