What has more Torque???
   / What has more Torque??? #11
Only as a generalization, the two cylinder should have more torque, but for the stated reasons by other posters, it's not cut-and-dried.
I've actually seen two cylinder Yanmars out-perform 3 cylinders with a little more HP.
John
   / What has more Torque??? #12
John
   / What has more Torque??? #13
Torque has nothing to do with the # of cylinders. Diesel will have a bunch more torque than gas, and a longer stroke engine will have more torque than a short stroke one.
Ralph
   / What has more Torque??? #14
Ralph
   / What has more Torque??? #15
Wouldn't the weight of all that spinning mass have to do with torque? I know a rod and piston out of a Cummins is one heavy chunk of metal.
   / What has more Torque??? #16
   / What has more Torque??? #17
The only thing that matters is what rpm you're measuring the torque at. If they both make 10HP@10RPM, they both have 5,250 ft/lbs of torque. If they have the same displacement, then the longer stroke of the 2cyl is offset by the larger number of power pulses per rotation of the three cylinder. It's really a question of torque curves rather than absolute torque, and that's something that can really only be determined by looking at dyno charts of both engines.
   / What has more Torque??? #18
   / What has more Torque??? #19
</font><font color="blue" class="small">( The only thing that matters is what rpm you're measuring the torque at. If they both make 10HP@10RPM, they both have 5,250 ft/lbs of torque. If they have the same displacement, then the longer stroke of the 2cyl is offset by the larger number of power pulses per rotation of the three cylinder. It's really a question of torque curves rather than absolute torque, and that's something that can really only be determined by looking at dyno charts of both engines.
)</font>
Best comment so far on the subject!
Back in the early 60's, Ford quit using a 4 cylinder, and replaced it with a 3 cylinder in several tractor models. Power, specifically torque increased dramatically. That was always credited to the reduction of cylinders, and increase in stroke. While those facts made a significant difference, you need to look at fuel delivery systems, cam and valve train redesign, increased mass of the flywheel and crankshaft, and better piston design. There is no "magic formula" to increase torque. As stated in my first post in this thread, # of cylinders CAN have an effect on torque, but on its own, is not always the answer. Rotating mass is more likely to effect torque #s. (i.e. a 200 cu. in engine with a 75 lb crankshaft will more than likely have more torque than a 200 cu. in. engine with a 50 lb. crank, but not as a "hard and fast rule".[ Assuming BOTH operate at the same RPM's.])
   / What has more Torque??? #20
)</font>
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A55302)
2023 NEW HOLLAND...
2000 POLAR TANK TRAILER TRANSPORT TRAILER (A55745)
2000 POLAR TANK...
2012 PROCO KILL TRAILER (A55745)
2012 PROCO KILL...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A55852)
2019 Ram 1500...
2007 Hannay reels Hose Reel (A54865)
2007 Hannay reels...
