What have you broke being stupid?
   / What have you broke being stupid? #31
Borrowed a friends old case crawler dozer/loader, was pushing a stump across the field and up on the burn pile, the bucket was tipped down and went over the top of the stump as I pushed it up.
rolling back,
It put a root through the brush guard and radiator.
I bought him a new recore radiator @ $300.00
He thanked me saying the old one leaked a bit.
I said you should of seen it with the root in it!! :rolleyes:
   / What have you broke being stupid? #32
No one particular incidence comes to mind at the moment but I do recall several of them were preceded by the words "watch this" or "what do you mean it won't do it, watch this" etc. etc...
   / What have you broke being stupid? #33
Pulled a skid steer out of a ditch with a truck and broke the hydrolic drive motor shaft. what no nutural? Could have used the bucket to get out.
   / What have you broke being stupid? #34
The first week I had my tractor I put a large, heavy duty D-Ring on the back to use to pull mya chain harrow. What I didn't realize or notice was that when the D-Ring swung to one side or the other it was in the way of the lift bar on that side. WIth dumb luck nothing happened for quite some time as I raised and lowered the belly mower with the D-Ring still on there, but finally one time the D-Ring was all the way to the right and when I lowered the the mower it caught and after a brief struggle over what part of my tractor would break.... the lift arm on the side bent badly. Live and learn!
I've been married for almost 29 years so when I do something stupid it does not really surprse me much.... and my wife is surprised not at all! :)
Roy
   / What have you broke being stupid? #35
I've run over my 034 stihl twice with my L4400, both times I needed new fuel tank assembly, one time I was able to bend the handle back, the last time I got a new one on ebay. But...tis an ill wind that blows no good, I'm reall good at taking apart and putting back together my chainsaws
simonmeridew
   / What have you broke being stupid? #36
Hi, I to have had my share, one that comes to mind is driving my fathers john deere combine into the barn in the rain with the auger out. I don't remember the replacement cost only know it never worked right after that. I sure dreaded going in the house to tell my dad about that one.
   / What have you broke being stupid? #37
I too have done numerous stupid things but recently instead of waiting for my tire chains I decided to push on and got my Bota stuck 3 times in a day with the last time being a good one slid 5 feet over into an old logging road trying to clear my neighbors driveway and had to call my friend who thankfully owns a tow service and pulled me out free of charge.
-Mike
   / What have you broke being stupid? #39
Today I was trying to dump some brush on top of a brush pile. I had the bucket raised high and was not thinking about how close I was. The tractor seamed to stop for a minute then I heard a crunch. I back up and saw that a 4" round tree that was sticking out of the pile went right in to the headlight of my new DX45. I have to replace the whole headlight assembly. I called the dealer to order a new one thinking I could just get the lens, to my dismay I had to order the whole assembly. It cost me $170 my wife was not to happy when she found out. I think it time to build a brush guard. I was wondering if any one else had any "DUH" moments they wanted to share:eek::p
I have a 1995 Escort with 224,000 miles on it. It has had starting issues lately that came on slowly. I assumed that the catalitic converter was plugged, it acted exactly the same as an old Pontiac I had worked on that someone had backed into a snow bank and plugged the exhaust with snow. I jacked it up and saw a fat spot in the exhaust pipe that I assumed was the offending part. I wore out two metal cutting sawsall blades while sweating profusely cutting the thing out with a sawsall. When it hit the ground I realized that it wasn't the catalitic converter at all. It was just the resonator in a perfectly good 15 year old stainless steel exhaust pipe.
I not only broke it being stupid, but I worked my butt off to do it! It cost me $15 to buy a pipe and a couple of clamps to replace it. The replacement parts are carbon steel and will probably only last 3 or 4 years.:eek::eek:
As it turns out the coil pack and spark plug wires had gone bad, causing the problem. $80 worth of parts and a little wrenching and it is back to running like new.:D:D:D
DUHH :eek::eek::eek:
   / What have you broke being stupid? #40
I broke my tooth by sticking a screw driver in my mouth instead of a toothpick. It was one of those fine eyeglass screw drivers and I jerked it and it split my tooth right down the middle - I just had it pulled out.
I didn't have the guts to tell the dentist as he was stumped how the tooth split.
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A56858)
2007 Western Star...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
KMC POULTRY HOUSE KEEPER (A58374)
KMC POULTRY HOUSE...
2015 Ford Focus Sedan (A56859)
2015 Ford Focus...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
