SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 10,393
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
I see what youre saying. Friction in the faster flowing fluid will be greater, causing pressure against the pump to be higher based on how much pressure it takes to flow the greater amount to and thru the relief valve. Looked at another way tho, the PD pump does not require much speed to develop its full rated pressure, and only a little more to break it unless its relieved. On the other hand, non PD pumps rely on speed to develop their pressure. Speeding them up is the only way to get more pressure from them. As you say, this only works within a limited range - altho often a fairly broad limit if your not expecting linear increases.Egon said:PD = Positive displacement pump. If this type of pump is speed-ed up the increased volume flow resistance will increase the output pressure on an ongoing basis.
On a centrifugal pump this pressure will increase to a certain degree but stop increasing when the pressure limits of the vanes or stages are met.
Iplayfarmer, what kind of pump are you talking about??
larry
