What implement for road gutter maintenance?
   / What implement for road gutter maintenance? #1
stumpfield
Sierra Foothills
2005 MT265B
What implements is best to maintain the gutter of a long driveway that hugs along a fairly steep hillside? It's a little tough to do it with the box blade tilting to one side. I'm hoping there a specific implement for this task. I have almost a mile of driveway that needs to clear the gutter for drainage a few times a year or the road got wash away. Any help is greatly appreciated.
   / What implement for road gutter maintenance? #2
I’ve always used a rear blade for cleaning up the ditches. The inexpensive one that I have will allow the blade to off set or swing to the side keeping the tractor on the drive. The blade also tilts up to about a 45 degree angle to scrape the ditch.
MarkV
   / What implement for road gutter maintenance? #3
I vote for the rear blade too. I use one to create ditches and waterways by angling the blade and lowering the forward side so it plows. an offset style as MarkV suggested would be just the ticket for you. You could even make a custom extension for the leading edge that was rounded to fit your ditch bottom, leaving a nice clean radius.
   / What implement for road gutter maintenance? #5
How about a pond scoop?
   / What implement for road gutter maintenance? #6
I use the FEL and the Back Hoe on my BX23
   / What implement for road gutter maintenance? #9
Rear blade. One with the ability to offset quickly and easily prefered. Those that can angle the main beam simply by lifting a pin seem to be the easiest.
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A49461)
1994 Mack CH613...
2018 John Deere R4038 Self Propelled Sprayer, (A50657)
2018 John Deere...
Non running toro mower (A48082)
Non running toro...
2018 East Texas Utility Trailer (A49461)
2018 East Texas...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2007 Volvo VNL Truck Tractor (A51039)
2007 Volvo VNL...
