What Implement Will You Be Buying For 2011?
   / What Implement Will You Be Buying For 2011?
Ken--Dont want to get to much off the thread, but in your opinion how is this tarter tiller and hawkline tiller stand up to the Sicam ones. I have heard a lot of really good things about the Sicam tillers but not much on the tarter? Whats the price difference.
AndyG
The Hawkline is coming out of Ohio and the Tarter is coming out of Ky. The Sicma.Phoenix are coming out of Italy and I suppose some of the difference in price would be shipping costs. I have had real good luck will all 3. No drive train failures on any of them. The 72 inch Hawkline and Tarter are $1695 (geardrive) and the Sicma/Phoenix 74 inch gear drive is $2195. Sicma/Phoenix does make a 72 inch (T8-72) chaindrive model for $1995. Ken Sweet
   / What Implement Will You Be Buying For 2011? #22
Ken- I have a B26, how big do you think I can go on a tiller? I think that's the highest on my list right now.
   / What Implement Will You Be Buying For 2011? #23
Tooth bar for my bucket. 42" so I will probably have to by the smallest I can find and cut and weld it to fit.
Also a mini grapple. I'm sure there are plenty of those around:laughing::laughing::laughing:
   / What Implement Will You Be Buying For 2011? #24
Thanks Ken--- You got any pics of the 60inch tarter tiller?? I can get a KK locally for 1500+tax but have seen some of the 4ft KK have their lower pins bend? So I am very interested in seeing the tarter 5ft pic:)
AndyG
I believe that a 60 incher would cut out your tracks and pull fine in most soils. If the soil is heavy clay, you may want to drop back to a 48. Ken Sweet
AndyG
Here is some info that may be of help. We have never had the pin problem with the Tarter. Ken Sweet
   / What Implement Will You Be Buying For 2011? #27
I need a 7' sickle bar mower and a 6' tiller. The mower is pretty much a must-have item, the tiller is something I want but am not 100% sure of at the moment. That will depend on a few things (which will be the topic of another thread). Those sickle bar mowers are so darned expensive so I might try to find one used locally, I don't know yet. I might try to set up remotes so I can get one that has the hydraulic lift/lower capability. Just takes $$...
We have several used Pitman style mowers that run from $695 to $895 and have been run thru the shop. These mowers will approx 35 degrees above and below horizontal with no cylinder required. We also have 6 used belt drive mowers that will mow 70 degrees below horizontal and 90 degrees vertical. I have 4 7 fts and 2 9 fts. Prices on those run from $1195 to $3150. We also have the new Enorossi 7 ft mowers with hydraulic cylinder for raising to transport for $3695. I will post a few of them below for reference. Ken Sweet
   / What Implement Will You Be Buying For 2011? #29
We have very heavy clay and I have R4's so I'm guessing the 48 would be the way to go... Thanks for the help.
   / What Implement Will You Be Buying For 2011? #30
Lookin to pick up a little 2 basket Tedder...
2022 Horizon Trailer (A55973)
2022 Horizon...
Dodge Charger (A56859)
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
PENDING SELLER CONFIRMATIONS (A59575)
PENDING SELLER...
CATERPILLAR 308D CR EXCAVATOR (A59823)
CATERPILLAR 308D...
