what is 5w40 really?
   / what is 5w40 really? #1
BrettW
Platinum Member
now in S.C.!!
Yanmar FF205D
I just bought Rotolla 5W40 Syn, seems to work very well, but what the heck is it really? 5W with stuff mixed in to make it thicker if needed? OK to use in a diesel? It is Ch4 rated. thanks, bw
   / what is 5w40 really? #2
<font color="blue"> OK to use in a diesel? It is Ch4 rated. </font>
You answered your own question. /forums/images/graemlins/grin.gif
   / what is 5w40 really? #3
I've seen Mobil 1 in 0W40. The common grades around here are 5w30 and 15w50. They can control the PAO reaction process to get the proper viscosity index and weight. I asked a guy who used to work for me (and is still working for ExxonMobil in the lube oil area) who was privy to the Mobil secrecy stuff even before the merger.
Think there are very few additives in PAO (poly alpha olefin) synthetics. Whereas, dino oils with even 10w40 vis spread would have 20% additives. One of the additives is a viscosity index improver that moves the VI from out-of-refinery level of 105 up to 140. Think most of the base dino oil is around a 15w. The VI improver moves it to the typical non-syn 10w40 level.
Ralph
   / what is 5w40 really? #5
My understanding is that the lower number is the base viscosity and additives make it thicken up to the higher number when hot.
Could be wrong, but this is my very basic understanding of how multi weight oils work, regardless of synthetic or not.
Ben
   / what is 5w40 really? #6
Pretty true for dino oils: lower number is base and higher number is what you get with VI improvers.
For synthetics, they come out about 140-170 VI without additives. They also come out naturally low in pour or fluid point and don't need this additive. Think they probably still add some of the detergent stuff, particularly to keep diesel solids in suspension, etc. However, they won't have the VI improvers or pour point depressants that seem to be the ones that either break down and cause the oil to thin out or goop up and make it more viscous.
Ralph
   / what is 5w40 really? #7
Ralph,
You have really confused me now ??? How is there different weights of synthetic oils if they are all 140-170VI ? Not disputing anything, just confused.
Ben
   / what is 5w40 really? #8
The weight is the viscosity of the oil. This changes with temperature. The W stands for winter. When the temprature of the oil is 0 degrees it has the same viscosity as a 5 weight oil, and at summer temp it acts as a 40 weight oil would.
Learned in tractor school 30 years ago. Go Aggies.
   / what is 5w40 really? #9
That is what I thought 5W40 would have a Viscosity of 5 at zero degreees and 40 at operating temps. Same for syn or dino.
2011 Chevrolet Uplander Van (A51694)
2011 Chevrolet...
2016 Ford F-550 Altec AT37G 37ft Insulated Bucket Truck (A52377)
2016 Ford F-550...
2022 BRAZ0 40FT PIT BOSS BELLY DUMP TRAILER (A54607)
2022 BRAZ0 40FT...
2012 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A52377)
2012 International...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2021 Allmand Bros...
