What is a good / cheap Post Hole Auger?
   / What is a good / cheap Post Hole Auger? #1
tomrscott
Newberg, Oregon, USA
JD 790
The wife decided I can have a post-hole auger if I will build her a raised-bed garden and gazebo with it (setting a bunch of 4x4 posts). So our ground is mostly very good top soil down to at least 3'. Some rocks but not usually anything huge.
So, ... I don't think I need anything real heavy duty. The biggest job would be that I'd like to get a large diameter auger for digging tree and shrub planting holes. Probably need a 9" and a 12" auger.
The local Wilco Farm Store sells KingKutter stuff probably as cheap as anything. What is a good price for one?
Are there any that should be avoided at all cost? Or features that I should hold out for? Do they all have good bearings with grease fittings?
And I haven't studied one up close, how do they transfer the power up the boom? Is it some sort of flex shaft? Or just a couple of universal joints? Or is this an area where they differ?
Thanks! /forums/images/graemlins/smirk.gif
   / What is a good / cheap Post Hole Auger? #2
Tom,
They all use a PTO shaft with u-joints. I have a Brush Hog digger and I am real happy with it. If you are only using it on your place, there are several brands that will work.
   / What is a good / cheap Post Hole Auger? #3
I have a Lienbach L7400 with a 12" auger I bought last year for under $400. I have just at 5000 trees to plant with it. So far I've bored a few hundred holes without any problem. I've hit roots and some baseball sized rocks without issue. If I had to point out a difference between this "economy" model and some that I looked at that cost 3 to 4 times the amount, it seems that the more expensive units have heavier bits and some have slip clutches rather than shear pins. I added a slip clutch to mine for about $70. So far, so good. Just another 4600 or so more holes to bore... /forums/images/graemlins/shocked.gif
   / What is a good / cheap Post Hole Auger? #4
I just purchased the SpeeCo standard duty model from TSC. The cost with a 12" auger was $559.00 including tax. The tip and cutting edges are replaceable. It seems like it is a good as the rest I looked at. I have only dug 1 test hole through some frozen soil and it worked great. I have some areas that is clay and others that is gravel and sand.
   / What is a good / cheap Post Hole Auger? #5
I have a Lienbach with a 12 auger. I got it as a package with my tractor for $300 two years ago. It's works great, but it's the only one I've ever used, so I'm not very knowledgable.
Mine has 3/8 bolts for sheer pins, which I'm going through like crazy right now. In clay, it works fine, but I'm going through a section of iron ore with an ocational tennis ball sized rock that just snaps the sheer pins.
With another hundred feet to go, I'll just keep putting in .26 cent bolts until I get through it, though a clutch would really be nice right now.
I thought the 12 inch auger was too big when I bought it, and it's one of the reason's I got a good deal on it. Nobody else wanted such a big one and it had been sitting on the lot for too long. Now I wouldn't own a smaller one and really want an 18 inch one. It's allot easier to put the dirt back in then to get it out when your hole is slightly off or you hit a root or rock and the angle changes on you.
   / What is a good / cheap Post Hole Auger? #6
Have you checked into renting one ???
   / What is a good / cheap Post Hole Auger? #7
I'm glad that I'm not the only one who is annoyed by breaking shear pins on a PHD! Well, I don't mean that I'm glad you have the problem too. /forums/images/graemlins/blush.gif Uh, you know what I mean. I guess you know why I added a slip clutch when I have over 5000 holes to dig. /forums/images/graemlins/cool.gif
   / What is a good / cheap Post Hole Auger? #8
No problems with my Spee-co!
So here are the options I've found in a couple days of looking around locally:
1) Wilco Farm Stores - New Speeco (Model 65 I think) with 12" auger $529 after farm discount
2) Valley View Tractor & Equipment,Inc (Steven Roy, friendly local dealer, like to give him my business if I can) - New Howse with 12" auger $600
3) Valley View Tractor & Equipment - Lienbaugh medium duty, lightly used, but a slight kink in the drive shaft keeps it from collapsing all the way (probably could straighten it) w/ 9" auger (I really want a 12") $425. I'm thinking he might take a lower offer, and maybe swap in a 12" auger.
4) Northern Tool - Unspecified brand, w/ 12" auger $505 + $160 shipping(!) = $665
5) And then there's the local guy who specializes in restoring manure spreaders, got 'bout a dozen of them in various states of disrepair, and plenty of aromatic test material all over his place (he met us at his back door wearing knee-high rubber boots and we didn't wonder) - He had two of the most peculiar looking old antique post hole diggers I've ever laid eyes on One with a 5' depth capacity, but the drive line was solid and not collapsible at all (???), I don't know how that is supposed to work? I finally decided I wasn't sure my tractor would lift it high enough to get it off the ground. He said it was built by some local outfit from car transaxles. The price was right at $200, but it looked like too much of a project. I think I would have had to fabricate and weld on a collapsible drive line, and then there is no telling what kind of shape the gear box is in. He said the other one was an old antique Ford post hole digger, very peculiar construction, wish I had taken a camera and taken some pictures.
Been checking all the classifieds and Nickel Ads, and looked at some farm yard sales.
Couple more dealers in the area that might be good sources for used deals, I'll check this week.
#3 looking like the best deal if he'll dicker a bit, probably #1 is my second choice.
/forums/images/graemlins/ooo.gif
As far as I know, there isn't a TSC anywhere in Oregon, or maybe the whole Pacific Northwest, but this is what their online web shows when I look it up:
<font color="green">
"Please check with your local store for the most accurate pricing information and product availability. Prices listed are subject to change without prior notice. We reserve the right to correct pricing errors and to limit quantities.
Quick and easy holes. Fits category one or two 3-pt. hitch. Nine or 12 inch augers. Shear pin protected PTO drive.
POST HOLE DIGGERS "
TSC # PRODUCT PRICE SHOPPING LIST
2118948 POWER UNIT ONLY $384.79
2119279 9" AUGER ONLY $114.52
2119287 12" AUGER ONLY $138.36
2121836 6" AUGER ONLY $106.28
</font>
So a digger with 12" auger would be $523.15, or about the same as the Wilco price I had.
Could that be a local sale? /forums/images/graemlins/ooo.gif
   / What is a good / cheap Post Hole Auger? #13
That might be a local sale. When I checked with them, they asked for my zip code, (which is near a mid-west store). The prices they quoted you are higher than what I saw.
Rather interesting - the regional pricing. I suppose it reflects shipping.
Well it could be shipping, but it may also have to do with local inventory.
If a store gets too much inventory their "inventory turns" get to looking bad and it becomes worthwhile to clear out some excess even if the margins aren't good (from their perspective). It can be real hard in retail to predict what inventory to carry. If you don't have the products in stock you will lose sales, which hurts your revenue, but if you have too much product, it reduces inventory turns, which hurts your profitability.
John Deere 50 (A60462)
MASSAGE CHAIR (A58214)
1989 AM General M998 HMMWV 4x4 Humvee Truck (A59230)
1989 AM General...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
2019 CATERPILLAR 259D3 SKID STEER (A60429)
2019 CATERPILLAR...
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
