What is a "normal" amount of FEL leak down?
   / What is a "normal" amount of FEL leak down? #11
Re: What is a \"normal\" amount of FEL leak down?
I had a similar leak down issue on my small Kubota when I purchased it. I first swapped out the loader valve, then discovered that wasn't the problem. The issue was a bad lift cylinder that was leaking by the seals internally. Dealer replaced with no issues.
   / What is a "normal" amount of FEL leak down? #12
My FEL leaks down about an inch per hour when parked empty.
The bucket roll-back on my 410 is actually worse. It leaks enough to be noticable during use. When moving a full bucket load of material over a distance, I have to periodically tweak the bucket back up stuff starts jumping out.
I'm not satisfied with the amount of roll-back in the 410 loader design to start with, and the leaking makes it slightly more annoying.
- Rick
   / What is a "normal" amount of FEL leak down? #13
I have to agree that the amount of leak down you have is not normal. If it were, you'd be hard put to move a good sized load on a large property without having to continually move the bucket back up. A very small amount over time is not unusual, but what you describe is. John
Kubota RTV X900 (A53317)
Kubota RTV X900...
2018 Ford Explore AWD SUV (A59231)
2018 Ford Explore...
2008 CHEVROLET C8500 DUMP TRUCK (A59823)
2008 CHEVROLET...
John Deere 2310 Soil Finisher (A59814)
John Deere 2310...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
