What is Grey market???
   / What is Grey market??? #12
Not all JD tractors have a yanmar engine in them. All the large Ag tractors will have an actual JD deisel in them whith a JD plate on the engine. The 20 , 30 and 40 series tractors and maybe the 50 series will have Yanmar deisel engines in them back into the 80's i beleive. Some of the older JD's like the 850 and 970 etc are exact copies of yanmars , i mean the entire tractor, same ignition key, same seat same hydraulics same starter same fuel bowl etc. I m not really a JD expert but i know this or 99% of it is true.
That said i do own a Grey market Yanmar tractor. Grey Market is a term used if that tractor was not built to be sold in the US. A general rule of thumb is that they did not have pto shields and rops. That is not the only rule. If yanmar USA sold YM2000's outside it as used tractors (not that they would, they do not recognize they exist here due to lawsuits) they would still be grey's. My Made for the japanees market Ym2000 tractor will fit all Cat 1 implemts made here in the US without mods. Same lift arms same PTO gears etc. I just happen to have a 3 speed Pto instead of a 2 speed which the US yanmars had. I can still get availible parts from yanmar USA if i tell them the us model number for the tractor (ym240) and i can even get parts from JD for certain things on my tractor if i know what they come off of in the JD line up. That is if i wanted to. I can buy them offline from HOye tractor (a yanmar parts supplier) and pay less for the same part to fit my tractor than from yanmar USA or JD. Some of these parts , which may not be in production anymore yes are made in china or india by a parts suppleir, but others come in a yanmar bag and would be the same thing i would get from JD or Yanmar USA. Just adding something to the conversation.
Basically you and I are saying the same things about Grey market tractors, but you are more in detail on other models. I just researched the Satoh Buck
and found out a lot of information. To be honest I passed up a great deal on a Yanmar with a bucket and bush hog because I was dumb when dealing with foreign tractors and at first I did not fully understand the full meaning of the term Grey market and I was scared to buy one until I finally did a lot of reading, glad I did. I keep my fingers crossed but so far I have not had to buy any parts other than filters and oil. My Buck still runs great and last night I re-read the operators manual and it is surprising how much you miss and can use additional information I missed.
I want to help those that may be scared of foreign tractors---As any thing it is best to know what you are buying and the condition of the tractor. I know some owners that avoided the Diesels and bought gas tractors, but now wish they had gone the other way. My tractor I used it almost all day today tilling a open field and making a garden spot probably about 1/2 acre or more. I ran it full power the entire time and had no problem.
I really need to use my tractor more often. The ballast problem in the front end can be solved in a great part if you reduce the throttle prior to turning and make sure you raise the implement before turning. I tried it today and found out the wheel stands were not as bad and was really caused by the heavy throttle speed.:)
   / What is Grey market??? #13
Unlike gas models deisels are desinged to be operated at full throttle and for all day if neccisary. NOt redlined but full working rpms, you will do more harm lugging a deisel than running at the rated rpm. As for throttle and light frontend, get some weight. I had about 80lbs on front of my yanmar with was great for tillers or bushhogs from being light, but when using the boom pole of my 4 ft disk with 300lbs on top, making it weight in the 600lb range the front was light almost neutral in weight. I have a friend who filled a 3" diameter pipe with lead and is welding it to my existing solid 3" steel bar i had made into a bumper. This should give me right around 200lbs on the front. The manual i beleive says 240lbs is what it is rated at. You can buy suitcase weights, they just cost, or you can get some railroad track and cut a piece to a deseired weight, by doing some calculations of the know rail weight obtained of the internet. MY problem was finding someone to cut the rail, this may not be a problem for you. Another way i thought about is welding up a box and filling it with scrap lead and steel like brake rotors etc. This could easily get you weight fast if u used lead wheel weights (where we got the lead for the bumper).
   / What is Grey market??? #14
What in the world?
I know Yamnar from the marine industry...a big name/ old name.
Now I see this Best used tractors.com....and flip...they are talking about me buying CONTAINERS of tractors...a or b grade
And What is the deal w/ them being all re-cons??? WHAT are the japs doing to wear out so many tractors that there is a huge market to refurb and ship them here by the container? What is the chain that put so many in the hands of the VC for refurb?
cw
I would say the market is not as huge as it used to be but still big enough to be viable. There are two kinds of tractors available for export in Japan. Used working and used junk. The junk and scraps are bought by Vietnamese labor factories for almost nothing which they spend almost nothing to salvage back together and sell to us for a considerable markup. The A and B tractors are marketed to any county looking for solid compact used tractors and are never purchased by the Vietnamese for refurb/salvage.
The reason for the high export ratio is taxation. The tractor has a yearly tax associated with it that is ever increasing. Why pay a huge tax bill on a used tractor when a new tractor has no annual tax. In Japan you pay the dealer to take your tractor when you trade it in. And if the dealer doesnt move it he will have to pay the tax so it is sold to an export yard. If the export yard doesnt move it then they pay the tax. So prices stay low to keep the flow moving. Of course worldwide demand has risen prices significantly and with the yen in the 80 range most of the advantages of the Japanese tractors are gone.
I flew to Japan each month to pick our tractors out in person. One or two bad tractors per container gets real expensive over time. Having a company send you tractors off a list of pictures and descriptions is like a 50 thousand dollar box of chocolates, you never know what your going to get.
your original question was what is grey market. It has been asked a thousand times on TBN with a thousand wrong answers. The basic definition is Grey market is that it is an "importation tag" it has nothing to do with how something is configured or built, sold or supported or who built it. It also has nothing to do with if it does or does not meet OSHA, EPA or any other regulation for that matter. It doesnt even really designate whether it is new or used. All it really means is the item being imported (and this could be a TV set, Tractor or spaceship) was not sold new in the country it is being exported to by the manufacturer.
Buck
   / What is Grey market??? #15
You buy "b" grade tractors. In the description they give it means say all seats need replacing less than XXX hours no transmissions problems. I made this up but im sure there specs that allow a tractor to make it in the container, if you have a blown up one im sure they will make good on it. But i think you get like 10 tractors in a container dissasembled with the 3pt arms off the tires off, and there stacked in there. Based on what these older YM models have sold for, with those who purchase the container having to put a new seat on all flid changers some new seals and maybe paint and still turn a profit i think they are no more than a couple thousand per unit mabe half that, but with customs fees shipping etc i can easily see having 20-30 K tied up in one container before any refurbishing costs.
Our last container (last week) cost us $54,000 the Yen was at 84 to the dollar !
   / What is Grey market??? #17
Grey market tractor are OK but make sure you know what you are buying. Some grey market tractors have an American counterpart, part are eaiser to find but if you buy a tractor which wasn't ever sold in he US even under a different name you could have plenty of problems finding parts. And when you do you will pay dearly for them. I own an Iseki TS2205. Iseki's were manufactored under the White. Bolen, Allis Chalmber and other labels to be sold in he US, but a TS2205 doesn't have a counterpart in the US. Some parts must be bought in Japan, others can be bought used. I bought a gasket for a water pump and it cost me nearly $40.00.
So make sure you know what you are buying!
Don
   / What is Grey market??? #18
Don
$40... WHY. You can make gaskets out of gasket paper. Thats the way all old farmers and poor folk did it 50 years ago before easy replacement parts. Or you can use RTV.
   / What is Grey market??? #19
Buck
I heard a dealer on hear about a year ago say that good ym's (yanmars) were getting hard to find as the VN market was buy ing up many tractors, which contradicts what you say here and what others have said. Supposedly they are not buying the same tractors as you guys so why is there competition felt? Makes one wonder? Just repeating what i heard. I have not considered getting into this, i just frequent these forums.
   / What is Grey market??? #20
Sorry to say that your (dealer friend) is mistaken.
Our supplier in Japan has plenty of machines for sale (nice tractors) since the 1980s
They say that when the vietcongs buyers show up to buy tractors, they still head for their junk pile, they don't even look at the nice ones $$
The Vietcong tractors are rebuilt junk..... nothing more than lipstick on a pig.
2023 Jeep Compass Trail Hawk 4x4 SUV (A51694)
2023 Jeep Compass...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
2019 Ford F-550 Truck, VIN # 1FDUF5GT5KDA27067 (A51572)
2019 Ford F-550...
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
TEYME 2000 E0L0 GTE10 LOT NUMBER 228 (A53084)
TEYME 2000 E0L0...
Scag Mower (A50324)
Scag Mower (A50324)
