What is/ how do you / SLope Bench cut
   / What is/ how do you / SLope Bench cut #1
ramon49
oregon
L3130
Someone said they cut trails or bike paths in the side of gentle hills/slopes. May I have pictures or advice on how to get started. Do you use the hoe???
Ramon 3130/hoe/fel..big ones..
   / What is/ how do you / SLope Bench cut #2
Up and down. Up and down. That's the way I handle all mowing and bush hog work.
   / What is/ how do you / SLope Bench cut #3
Well, I haven't done it with a machine, but here's a link defining bench cuts: http://www.imba.com/resources/trail_building/contour.html
This is really hard work when doing it by hand, expecially in rooty & rocky terrain.
My plan is to back across the slope, using the hoe to do the benching so the tractor is always on the level ground that's just been reshaped.
   / What is/ how do you / SLope Bench cut #4
Using the bucket for a side hill trail : Note my method is for a small Kubota B7100 Hst. and It needs all the help it can get. That is why I start at the top. Normally one would start at the bottom.
Start at the top and dig in getting a bucket full. Back up and drop dirt on the low side. Keep repeating this till you are level side to side. Then continue forward doing the same always keeping your working area the tractor wheels are on level from side to side. It's a repitcious action and takes time and patience. Use caution when locking rear wheels as locked they have a tendency to go downhill. Always keep the bucket low.
The same method works if you start at the bottom.
Egon
   / What is/ how do you / SLope Bench cut #5
If the slope is gentle enough to comfortably ride sideways on it you could use a straight blade or box plade tilted downwards toward the high side of the hill to cut the trail.
Would need to be very careful doing it that way.
Alternatively, if you can start on a flat spot you can use the FEL to cut the trail.
Seems to me either of those would be faster than a backhoe.
Bill Tolle
   / What is/ how do you / SLope Bench cut #6
</font><font color="blue" class="small">( Up and down. Up and down. That's the way I handle all mowing and bush hog work. )</font>
I'm not too bright, that's just my bald head. I was thinking in cutting brush. Oppppsise.
I have a slope on my hill that has a small path that I can take my B7500 up when it's dry. I guess it's 50" wide but it's not as wide or level as I want. As soon as it drys up the box blade and FEL will make it a little wider and level it out.
   / What is/ how do you / SLope Bench cut #7
I agree that the loader should be faster than the BH on relatively gentle slopes. The only problem is that it would be difficult to properly shape the backslope with the FEL. I'm guessing on steep sideslopes the FEL would be really tough to use for this application.
Professional trailbuilders typically use walk-behind mini-dozers like the Toro Dingo or Ditch Witch SK500. These still require a fair amount of handwork (or BH) to do final shaping.
I know very little about tractors (so far), but have built a lot of trail. My BX delivery is delayed 2 days because of weather. /forums/images/graemlins/frown.gif
AUCTION STARTS HERE @ 9AM (A52706)
AUCTION STARTS...
2013 W-W TRAILER ENCLOSED TRAILED (A53843)
2013 W-W TRAILER...
Kubota ZG327 (A50120)
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2003 FREIGHTLINER BUSINESS CLASS M2 SPREADER TRUCK (A54756)
2003 FREIGHTLINER...
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
